Results 1 to 8 of 8
Thread: tuning genI motor
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    646
    tuning genI motor
    for anyone that doesn't know what my setup is for the dune buggy, it's a genI sbc with stock large valve body heads and a good size cam (234/234 .5xx/.5xx). brand new rebuild with a 9.0'ish CR.
    anyways, i've been fabricating a custom EFI ls-based system for it and i've come to the point now where I really need some help. I have no idea what kind of tune file I should start off with? maybe a 6.0 since it has a little more fueling? everything will function just like a ls1, except the motor at heart is the sbc350. I have all sensors and I do have a wideband and will upgrade to the pro interface before I start tuning (so I can log wb easily).
    the firing order issue was sorted out by just editing it within hptuners, so no worries there. also, we've engineered a way to fit the reluctor ring and cam ring on the motor and have the sensors work properly
    the pcm is a 2000 truck pcm and same for the harness. dunno what OS is on it right now. any help/suggestions would be great.
    '20 AT4
    '01 Suburban 2500 Dad Wagon
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,256
    I have a hpt file from a 2002 GMC Savana 5.7 (R) that might be of interest. Let me know, as I'm at
    work right now.
    Russ Kemp
    Oct 2006
    Houston, TX
    646
    that sounds awesome. thanks russ
    you always save my ass somehow lol
    jake
    '20 AT4
    Dec 2005
    Regina, Sask.
    4,256
    Here you go, these vans use the Vortec 5.7 engine. You might want to use a pcm from the full size van as it is fully supported by Hp Tuners.
    Russ Kemp
    Oct 2006
    Houston, TX
    646
    I already have a pcm/harness from a 2000 truck. pretty popular pcm so I'm gonna stick with that. I wonder if I could flash this file on that pcm? i'll check it out. thanks russ,
    jake
    '20 AT4
    Oct 2006
    Houston, TX
    646
    os is different. I'll try it anyways. if not. I'll just copy over some fueling tables, that'll do.
    jake
    '20 AT4
    Apr 2020
    4
    Russ please contact me
    Arizona
    1,281
    Quote Originally Posted by Dan Smith View Post
    20 year old thread...
    good job
