Results 1 to 3 of 3
Thread: AFR Question
    Apr 2023
    17
    Post AFR Question
    I install wideband and now log to tune NN and wondering why on idle the wideband line is straight and when im driving (normal driving) that make wave like on the image ?
    2012 chrysler 300C V8 5.7L RWDScreenshot 2025-06-02 175030.pngScreenshot 2025-06-02 175108.png
    Jul 2021
    236
    Not sure exactly what you mean, but your afraid will always fluctuate, the better the tune, the less variation. But changes in temperature humidity and altitude can change your fueling, so that's why you have o2 sensors
    2019 challenger rt
    92mm hellcat throttlebody
    ported 5.7 intake manifold
    ported eagle heads
    Cammotion custom 222/234 cam
    stainless works long tube headers
    Vs 78/75 turbo
    e-85 tuned
    3.70 lsd
    The wave-like pattern you see is the PCM varying the afr around stoich. The purpose of the variation has to do with how the catalytic converter works and maximizing the effect of the catalyst. I don't think the algorithms for the wave pattern are available to use using HPTuners; but you want it especially if you still have cats.
    The wave pattern varies in speed with engine RPM. At idle, the pattern fluctuates the slowest so it's not as easy to see.
