Results 1 to 5 of 5
Thread: P59 And Boost
    Sep 2022
    OK
    21
    Question P59 And Boost
    I've seen a bunch of threads about the the P59 with 2/3 bar OS and the reduced resolution in the VE table. Question is : If you had a good running vehicle with a P59 and wanted boost, would it stop you from doing the boost addition or is it not really an issue? My vehicle is not a daily driver, but I like it to drive good. It currently idles around 55kpa- 6.0 engine with BTR TN cam.
    Oct 2004
    678
    Not an issue. Untold thousands of vehicles are forced induction with a p59 computer.
    Jan 2023
    Canada, Eh?!
    8
    +1
    I am running 2-bar P59, LQ4 (stock cam), 7875, 4L80.
    I have absolutely zero complaints about daily driving it with the reduced resolution. If your VE table is reasonably smooth, it is no problem at all.
    1961 Apache: Shortboxed, pancake, step-notch, air-ride, boosted-LS
    1977 Silverado: The Daily - shortboxed & dropped, potato-potato
    V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7lbs in a 1lb bag
    Lotus Super 7 Replica: Scratch-built street-legal rollerskate
    Sep 2022
    OK
    21
    Thank you both, I will proceed with ordering part$ !
    Dec 2019
    MS
    1,238
    Its not that big of a deal. The main thing is if you want it close to perfect as possible filter out all the data between the axis scales.
    So if you have a MAP axis if 110 130 150.
    Then make sure to filter out all the data except a few numbers above/below the axis numbers. Its time consuming but atleast it will be the best you can make it.
