Results 1 to 20 of 30
Thread: LS3 cold start problem
    Jun 2025
    High Desert, NM
    12
    Hi, just joined. Need some advice.
    I built a Factory Five 33 hotrod with a new Gen 4 LS3 engine. I bought the engine from GM Connector and Cruise along with the ECU and all the wiring. The ECU was programmed by GM, the engine ran great.
    It now has 2400 miles on it and generally has to crank for 5-6 sec when cold. It always use to start almost instantly. Fuel pressure is at 58 psi. The trims look good. After it’s warmed up it always starts almost instantly.
    I haven’t bought the HP Tuner yet, not sure if I’d know how to use it, I’m more of a hardware guy than software.
    Any recommendation on what to look at?
    Factory Five 1933 Ford, LS3 powered
    Dec 2019
    MS
    1,251
    Id be looking at crank and cam signals.
    If it has good fuel pressure its usually the ECM isnt seeing cam signal and take awhile to fire up.
    Jun 2025
    High Desert, NM
    12
    Will do, thanks for the quick reply.
    Hook up a fuel pressure gauge to it after you drive it. Leave it on as it cools down. See how much pressure is bled off as it cools. Also, does it start quicker if you double prime the pump? In other words, turn the key to run but not crank for about 3 seconds. Then do this again, but this time start it.
    Jun 2025
    High Desert, NM
    12
    The regulator has a gauge.
    Can’t do much testing today, got company. Will do more tomorrow, like check the cam and crank sensors.
    Here’s what I did so far.
    Key on, pressure goes up to 58 then the ECU turns the pump off. Pressure immediately drops down to 44.
    If I double prime it same results. Tried this in past, doesn’t help it start any quicker.
    After 10 min the pressure has bleed down to 30 psi from 44.
    The fuel pump is new, it’s below and external to the tank.
    There are filters before and after the pump.
    The regulator has a return line back to the tank.
    There is no check valve in the supply line.
    After 30 min the pressure has dropped to 20 psi
    North Carolina
    4,846
    Is this only on hot starts or cold starts also?
    I doubt you would have made it this far but it's common for hotrod guys to not wire certain things like the PCM to hot while in start and run. They only get the run part. What happens is the engine doesn't fire until you let off the key a bit.
    Jun 2025
    High Desert, NM
    12
    It’s only on cold starts that it cranks for ~4 sec before it starts. When it does start it almost stalls then recovers and runs just fine.
    Double priming it when cold doesn’t help.
    On a hot start it starts right up and runs fine.
    For the last 2 years it always started almost instantly and idled fine.
    I’ve got a Foxwell NT710 scanner with GM and BMW software loaded on it.
    I’m still learning the GM part. I did hook it up and tried to capture live data, cam, and crank sensor data.
    I’m sure I did something wrong as I didn’t get any. I’ll keep trying.
    Is HP Tuners complicated? Maybe I should buy it.
    5BA8
    5,472
    email=[email protected]
    North Carolina
    4,846
    It might just need some tuning. The MAF placement makes a tremendous difference in fueling.. It's mounting is huge variable in swaps like yours. It likely could benefit from some tweaking.
    Jun 2025
    High Desert, NM
    12
    Alvin, thanks for the info, for the first 2 years it started up just fine. Nothing has been changed.
    I don’t have many placement options to mount the MAF. I tried to post a jpeg but it keeps saying invalided file type.
    Do I need more posts before I can upload a pic?
    Jim, could it be taking a while for the fuel to reach the engine from the pump/regulator/tank ? Small leak somewhere in the fuel system ?
    Jun 2025
    High Desert, NM
    12
    Quote Originally Posted by lewma View Post
    Don’t think so, the gauge shows 58PSI as soon as I start cranking it.
    Just to see if it is a fuel problem or sensor issue I think I’ll spray some starter fluid into the intake and see if it fires right up.
    Quote Originally Posted by JimLev View Post
    Just wondering if something is taking time to prime on a cold start.
    Aug 2021
    1,129
    Did I miss the log and tune?
    2,787
    Quote Originally Posted by LS ROB View Post
    He doesn’t have HPT
    5BA8
    5,472
    He doesn?t have HPT
    Good thing I got this ^^^ LOL
    Jun 2025
    High Desert, NM
    12
    I sprayed a little starter fluid in the intake, it fired right up.
    I replaced the gauge on the regulator, it read the same 58 psi.
    The Walbro fuel pump is new. There is no check valve in the fuel line, maybe it needs one to hold the pressure.
    As soon as I shut the engine off the pressure drops from 58 to 44 psi.
    I powered the pump directly without the engine running and could hear the fuel running thru the fuel rails. Sounded almost like there was air bubbling thru with the fuel. Once it starts it runs fine with lots of power.
    Feb 2018
    950
    When I didn't see a tune/log I was waiting for this...lmao
    Jun 2014
    Boulder, CO
    230
    HZow long does it take to show good oil pressure? After priming the fuel pump for 2-4 sec. upon key on, I *think* that the ECU doesn't enable the fuel pump again until it sees "good" oil pressure.
    Jun 2025
    High Desert, NM
    12
    As soon as the engine starts, when cold, the oil pressure jumps up to 50 PSI.
    The fuel pump comes on while cranking the engine.
