I was in aircharge and put the same value after tune AFR command to PRatio.
I ask a AFR command of 13.00 so I put 0.0081 (Fa Enrich-0.0688+0.0081=13.00) in the mid charge I put 12.80 (0.0090) and in WOT I put 12.50(0.0112). When I log and the engine is at 210F the AFR Command is at 14.7 yet I asked for 13.0. I am in Open Loop at 100% and COT disabled. I reset my ANN (Neural Network VE) and fuel trim. I disabled the PE delay and VSS delay in power enrichment. So when I start the vehicle I should always be in PE? But the AFR Command does not change 14.7 until I do a WOT or a MID pull. I logged the (FA Power Enrichment) in VCM Scanner it only activates at 3200/RPM under that it is at 0. What can I do?hp tuner.pnghp tuner 2.png
