Results 1 to 5 of 5
Thread: GMC Yukon XL Denali 2011 O2 disabling
    Feb 2023
    5
    I have GMC Yukon XL Denali 6.2 AWD 2011. Catalyst system cutted off. This is my tuned file and i have some concerns about flags and DTC errors, can someone advice which one can be switched off?
    Feb 2023
    5
    And this one stock file.
    405
    3,233
    You turned off all the O2 codes. You should turn back on all the sensor 1 codes. (pre cat O2s) And there is no reason to disable the system rich and lean codes.
    Feb 2023
    5
    Ok thanks a lot, it was as well my doubts as well as it was advice from one of the tuners.
    Feb 2023
    5
    Can you please take a look now at my tune DTC's? And on the pic is it necessary switch off as it related to rear sensors. Thanks a lot!
