Results 1 to 3 of 3
Thread: Tazer DT and the HP Tuner Smart Cable
    May 2025
    6
    I run the Tazer DT on my 22 Ram TRX. The HP Tuner Smart Cable plugs into the same port as my Tazer DT. I currently remove my Tazer DT before I plug in my HP Tuners Smart Cable. I would like to know if these two items are compatible and I can piggyback them together and leave them installed. Does anyone have experience with this?
    I just found out that the Tazer DT has a built in security gateway bypass module. I'm not sure how that would affect the Hp Tuners Smart Cable.....or, since the Tazer DT has a security gateway bypass module built in, can my MPVI3 read and write to the vehicle using the Tazer DT's security bypass module without having to install my smart cable?
    28,774
    yes you can use either. They both perform the same function ie bypass the security.
    May 2025
    6
    Sweet! Thanks Bill, no more crawling under the dash for me!
