I'm diagnosing an oil pump stuck in high pressure mode on my '13 Wrangler JKU. I came across a PID named "Oil Pressure Low/High" that seems relevant. Is that what the ECM is commanding or the present mode of the pump? I'm trying to determine if the ECM is actually commanding the pump to switch to Low pressure mode, or if the pump is stuck in high pressure mode.
