Results 1 to 9 of 9
Thread: low speed limiter
    Apr 2024
    26
    low speed limiter
    Does any of the polaris sxs have a low speed limiter in Low. Looking to see if the settings are similar to cfmoto.
    Mar 2024
    22
    do you mean max speed per gear? This is from a ranger xp 1000
    Apr 2024
    26
    Quote Originally Posted by 79 Bronco View Post
    What i have is, in low gear max speed is set to 16mph. When its tuned they increase it to 30. Buddy had his ecm sent out when he did the clutch kit and now it does over 30 in low.
    Apr 2024
    26
    Mar 2024
    22
    On that screenshot I posted it has speed limiter based on gear so it's set to limit low gear to 29 mph
    Park = 0
    High = 1
    Low = 2
    Neutral = 6
    Reverse = 7
    Apr 2024
    26
    Park = 0
    High = 1
    Low = 2
    Neutral = 6
    Reverse = 7
    Wonder if zero is seat belt then low high in normal mode then low high in sport mode. These machines limit speed to 12 if seat belt not latched. Thats what the atick number was at before i changed it
    Mar 2024
    22
    You could set each of the limiters to a different speed and drive it and you would soon figure out which one is doing what
    Apr 2024
    26
    opened a ticket with hptuners
    they added the missing fields
    Apr 2024
    26
    yes, only issue is my machine is at campground and I wont be up for a couple weeks. Trying to write multiple tunes to load and test when I go. This way I dont have to write while I am up there, just load each one.
