OK SO I GOT A LS3/6L80E ALSO A TAPSHIFT BOX IVE BEEN TRYING TO GET THIS TO WORK FOR AWHILE LIKE 2WEEKS CAN ANYBODY GO OVER WHAT I NEED TO ADJUST FOR IT TO OPERATE THANK YOU. E38/T43 ECUs IT DID SOMEHOW WORKED WHEN TURNED TRUCK OFF RANDOMLY DONT KNOW EVERYTHING IS WIRED HOW IT SHOULD BE. when i turn truck off it goes into WOT TUTD is there any other way where i can make d5 or d4 hold first gear
Under Shift Pressures, General, the Pattern B Shift is changed from Y to X. The TUTD MAN Shift is changed from Y to X. The pressure pattern modes for Y and Z need to be put back to special from normal. These changes are likely causing your issue.
Under Shift General Tap-Up/Tap-Down IP display should be changed to enabled (not sure if this really matters). However, on files I've used for Camaro's with tap shift these tables need to be changed back to stock.
Under General, Max RPM is 4,000 instead of stock 5500 for CMD Gear Control Limits.
