Just started tuning a Gen3 6.0 DBW with a 4L80E. It's been gone thru and is a cammed 6.2 with flat tops, 317's, .600/228 ish cam, 50# injectors. Tranny has been gone thru and has a 3200 single disc converter. It's in a '74 C10 with 3.73 gears and 29" tires, new everything.
This is the 2nd real tuning pass.
I have some knock going on when I first roll into it. I only pick it up under initial load, if I "pedal it" I don't seem to pick it back up but obviously the load changed so there is that....
Anyway I started with the stock tune and haven't touched much more than Idle Air, VE, and a few tranny parameters.
Should I decrease Knock sensitivity or should I pull some timing?
About 1:48 in you'll see some KR start.
short dr sd6.1.hpl
C10 Gen3 6.2 V4.4.hpt
