Results 1 to 20 of 20
Thread: Stft very high
    Jun 2025
    N/A
    7
    Question Stft very high
    I recently put together a LQ4 to replace the blown up LS1 in my 2002 WS6.
    Stock LQ4 block and crank
    Scat rods
    Wiseco -3.2cc flat top pistons
    TSP Bald Eagle NA cam
    PRC220cc as cast heads
    Stock ls6 intake
    stock ls1 tb and maf
    1 3/4 headers
    stock injectors resized to 42lb by Fuel Injector Connection
    I got a mail order tune and the car starts, idles, and runs, however the STFT are very high.
    Is this a sign of a vacuum leak? Or is there something else going on? I already verified fuel pressure isn't an issue.
    I have a wideband and smoke leak detector being delivered tomorrow, so I will do some more investigating, but wasn't sure if anyone seen this before.
    2,695
    "stock injectors resized to 42lb by Fuel Injector Connection" What does this mean? Decapped injectors? Did they supply full GM data for the "resize"?
    5BA8
    5,380
    Love the "verified FP is not an issue" instead of posting what it actually is and how it was tested.
    email=[email protected]
    Arizona
    1,217
    Quote Originally Posted by 00transamls1 View Post
    always post your datalog and tune or we cant really tell you anything
    Jun 2025
    N/A
    7
    440-6968.xlsx
    As_Found.hpt
    I apologize, the fuel pressure was tested using a fuel pressure tester screwed to the fuel rail. Pressure is constant 58psi.
    Fuel Injector Connection supplied the attached Excel file.
    Also attached is the current tune.
    5BA8
    5,380
    Might wanna copy over the rest of the injector data.
    Most of the time high positive fuel trims are caused by low fuel pressure. If you're confident the pressure is good (should really have a gauge on it the whole time you're tuning) and if your injector data is right the only thing left to do is dial it in.
    Jun 2025
    N/A
    7
    I had the gauge on it the entire time and the fuel pressure was consistent. I can only take Fuel Injector Connection's word on the fuel injector data so I am hoping it's correct for my injectors. The only fuel injector data I see that is not copied over is the short pulse adder. Is there something else that is missing?
    5BA8
    5,380
    Isn't that enough? They supplied complete data and you've chosen to use 2/3 of it.
    Jun 2025
    N/A
    7
    The tune was done by mailordertuner.com not myself.
    I will update the tune though and see if any difference. If i still have an extremely high stft I guess there's a vacuum leak or the injector data isn't correct (injectors don't flow as much as the file states). I can rule out a vacuum leak this weekend. If there is no leak then I may need to spend some more money and get new injectors and not the "resized" stock injectors.
    2,695
    I'm curious about how the "resized" injector and data works. Are they flow testing each resized injector? Are they trying to modify them all to a standard and sending standard data for all of them. The latter would seem to require better quality control than I would think they would have. Both seem like it would be hard to do for $40/injector.
    5BA8
    5,380
    Fixing the short pulse adder is not going to fix your problem. But it needs to be corrected. You need to dial it in. It's going to take some tooning.
    Jun 2025
    N/A
    7
    I am not sure. Their site states that they are flow tested, but the file seems generic and not specific to my order. Your guess is as good as mine
    "1-4 BUSINESS DAY TURN AROUND
    THESE WILL BE GUARANTEED FOR A 3 YEARS!
    FLOW MATCHED TO 1%
    Price is per injector."
    Jun 2025
    N/A
    7
    Thanks for the heads up. I was mainly wondering if anyone could tell if there was a vacuum leak that are causing the extremely high STFT's based on the log. I wouldn't think the fueling itself would be that far off, unless the injectors don't match the data provided.
    Oct 2004
    650
    So..... Your "tooner" did not even properly use all the injector data he was given. Do you think this makes it more or less likely that he put any thought whatsoever into the file you were given? Just something to think about.
    5BA8
    5,380
    If it was consuming enough air to cause the MAF to be lower than expected it could cause high trims. But a vacuum leak that bad should have other symptoms. Like a high idle.
    I'm not sure what a "Bald Eagle" cam is, but the VE is just slightly altered from stock and the MAF is bone stock. It needs to be tuned.
    Jun 2025
    N/A
    7
    I am at work so I don't have the cam card in front of me, but it's
    227/234 .600"/.600" 111 LSA 109 ICL from Texas Speed.
    Once I confirm no vacuum leak and install the wideband I will start modifying the tune.
    5BA8
    5,380
    The VE does not have the right shape for that cam. In other words, it's basically untuned at this point.
    North Carolina
    4,748
    It needs VE tuning.
    I'd suspect the tune for the fuel trims. The fuel trims being off means the base tune wasn't perfect. It honestly doesn't look like a great starter file. The VE appears to be stock.
    Short pulse adder from the injector data needs to be copied in along with the min pw stuff.
    There are transient min PW that need to be zeroed out or modified at least in the transient tab.
    Having said all that.. the basic diag/check out should always be done. The percentage of cars that come to me for tuning but have other issues is very high.
    Feb 2024
    345
    Seems overlooked alot too, not saying its the case here, but everything, especially related to air, in and exhaust out, needs to be assembled before even attempting to tune it, especially the exhaust or the O2s wont read correctly, and intake ducting should be in its final form before beginning calibrating the MAF curve
    5BA8
    5,380
    ^^^ All good points...
