Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: LS3 cold start problem
    5BA8
    5,448
    Quote Originally Posted by sgod1100 View Post
    When I didn't see a tune/log I was waiting for this...lmao
    It comes in handy LOLOL
    email=[email protected]
    5BA8
    5,448
    Quote Originally Posted by pannetron View Post
    HZow long does it take to show good oil pressure? After priming the fuel pump for 2-4 sec. upon key on, I *think* that the ECU doesn't enable the fuel pump again until it sees "good" oil pressure.
    If the rail is fully pressurized and the system has a functioning check valve it should fire almost immediately regardless of if the oil pressure is high enough to trip the sensor to activate the fuel pump. And being a swap vehicle it most likely does not have the feature you're talking about. Not a GMPP engine package.
    Jun 2025
    High Desert, NM
    12
    There is no check valve in the fuel system.
    I took the regulator apart this morning just to make sure there wasn?t any crud in it. Looked fine.
    While running its at 58. As soon as I turn the key off it drops to 44psi.
    I?ll order a check valve.
    Why can’t I post a pic? Is there a file size limit or do I need more posts?
    Factory Five 1933 Ford, LS3 powered
    2,760
    Quote Originally Posted by JimLev View Post
    I took the regulator apart this morning just to make sure there wasn’t any crud in it. Looked fine.
    I’ll order a check valve.
    Shouldn't it drop to zero with no check valve?
    5BA8
    5,448
    So we're on page 2 now with no data log or tune file. E'ry body still guessin.....
  6. #26
    2,760
    This is the one that doesn't have HPT. I'm doing a lot of water system modeling at work today, so I don't have anything better to do between model runs.
  7. #27
    Jun 2025
    High Desert, NM
    12
    No HPT so no data log….that info was in post 1.
    Just ordered a check valve, be here on Tuesday.
  8. #28
    Jun 2025
    High Desert, NM
    12
    Probably more than you wanted to know….
    It does go to 0 eventually. Inside the regulator the center of the diaphragm has a ball on it. That fits into a seat with spring pressure keeping it closed, not really a good seal. The fuel pump pressure pushes the diaphragm up, so when the pump shuts off the spring pushes the diaphragm and ball back down on the seat. The seat for the ball has a hole that goes to the return line to the tank.
    I’ll put the check valve on the output of the regulator to keep the rail pressurized.
  9. #29
    Jun 2025
    High Desert, NM
    12
    Check valve is installed, didn’t fix the cold start problem.
  10. #30
    5BA8
    5,448
    Time to buy HPtuners so you can move on to the next step.
