Its on a charger now. I'll add PCM volage and injector ms then resend.
Module voltage is dropping way down and I cant seem to get much more than 100 RPM out of it. I might need to get a new battery or the starter could be weak.
Here is the file from the other ECM I have. Going to run to the shop and grab a serious charger. Trying to avoid running to town for a starter.
it has a P1336 code fyi
That may be similar to a 315 code for a GEN 4 but I think it can also mean irratic crank / cam
[email protected] - [email protected]
The Junkyard ECU or the one I have been using? Could that mean Timing chain?
First thing is get a good battery in the thing. Voltage is WAY too low during cranking. Battery is junk.
email=[email protected]
It's an old battery, been in my Nova for about 5 years, probably has less than 1000 miles on it and sits on a battery tender 99% of its life.
Here is cranking with a jump pack. Still drops to upper 9v lower 10v
OMG please take some advice and put a battery in it. I don't want to look at another log without a new battery powering it.
And still only about 125 RPM. Gonna have to bite the bullet and get a new battery and starter, it will be a few hours. Where do you find the DCT's in the log?
New battery, new starter, same BS. Looks like crank position is definitely an issue here. I'm wondering if its acctualy 125 RPM or 250. Would a 52 tooth sensor read 1/2 speed on a 26 tooth reluctor, or would it just not read?
04 I believe. Pretty sure its the 24 tooth. Should have gotten the sensor PN when I had the starter off. I have one new in the box, GM PN 12703627, not sure if its the same one as installed on the vehicle. I'll take the starter off again.
Sensor from the car has no numbers, just a blue dot. Probably a cheap parts store brand. The other one I have is an AC Delco part but it does say China on it, looks like its the wrong one though.
Getting beyond my knowledge, but I don't think I would chase crank sensor to far at this point. If you can see the reluctor wheel with the sensor pulled, it might be worth a look at it and compare to some online pictures to confirm 24x or 58x. But I would think that since it is registering an rpm, the sensor is ok, at least for now. But I'm guessing about this.
Here is the date code on the block. From what I have found, I think it is 12/28/04.
Having trouble with attachments again. I'll try again later.
Not impossible someone previously put a 58x in an older motor. But a 58x would show up as higher rpm and not lower rpm.
