Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
Thread: 2019 L87 6.2 Silverado with LT4 injectors/pump
  1. #41
    Dec 2024
    Hi,
    Haha....the oem's make things difficult don't they!
    I've found a 3 phase fuel pump. Has anyone seen/used these E5LM fuel pumps in a Chevy?
    The flows and pressures look like an upgrade over factory pumps, obviously commissioning it in the truck is another story.
    There is a kit from TI Automotive that also includes a PCM but we all have those already
    Link to pump below:
    https://irozmotorsport.com/product/e...ess-fuel-pump/
  2. #42
    Follow up on my low side fuel experiments. I built an internal aux pump with the dw440 and their controller. I had a factory low side pump in the factory module running on the factory driver. I used a spare bucket with the dw440 pump in it t-ed into the factory pump feed just under the hat. This would work great, making 72 psi when activated, but I had trouble with the hobbs switch consistently activating it.
    In the meantime, I finally received a 2023 escalade V pump/sending unit. So being a simpler and potentially more reliable solution, I tried it. It's working fine, but only keeps ~50 psi of fuel pressure at 9 psi of boost with 72% ethanol. It makes 85 psi on 93.
    5.3 with L8T cam, 2650 with 105mm pulley, LT4 injectors and pump. Whatever power that is.
  3. #43
    May 2021
    18
    Quote Originally Posted by MeanMike View Post
    To confirm, the escalade-V is plug and play and an improvement over the oem pump on the 5.3/ 6.2's? It sounds like it might only be incremental improvements over the Silverado pumps.
  4. #44
    Yes, completely plug and play on my 2020 5.3 truck. It's working great.
    It might be a bit more of an upgrade than i thought. I changed pulleys yesterday going up about 11% blower speed and it's still cranking out 50 psi of fuel pressure on 80% ethanol. I'm guessing I'm in the 550rwhp range with this configuration.
  5. #45
    There are two differences. First the V module isn't as deep as the Silverado part, but it still seems to be right at the bottom of the tank when installed. Second, copy over these two tables for the sender from an escalade v file. My gauge stayed at 100% for the first 150 miles with the stock cal.
  6. #46
    Jan 2016
    Did anyone ever get a the TCM swap to work?
  7. #47
    Nov 2007
    Perth, Australia
    12
    How's the Escalade V pump & module going? I'm considering this as I can't find any other options for more low side flow in the 2019 onwards Silverado's.
  8. #48
    Quote Originally Posted by xsesiv View Post
    You just need the pump/sending unit (86825361). No need for the driver, your stock driver works fine. I'm having no issue with E80 spinning the blower 11,000 rpm (~10psi on a 5.3).
