Results 1 to 14 of 14
Thread: new fuel pump, still not driving, please help
    Jan 2025
    41
    New fuel pump log.hpl
    base stock tune start up tune 2.hpt hp tuner (1).hpt
    2002 lq4
    all stock with mild summit 8719r1 cam and springs to match
    please help me drive to the exhaust shop 1 mile away
    405
    3,249
    Quote Originally Posted by FASTRO VAN View Post
    Is this a swap vehicle? Are you trying to run it with open exhaust?
    Jan 2025
    41
    It is a swap, and yes the exhaust is open after the new Delphi o2?s
    405
    3,249
    You can't do that. Either unplug the O2s or set the tune up to disable closed loop until the exhaust is closed up by the O2s.
    Arizona
    1,323
    just have it towed.
    Probbaly what, $60?
    Jan 2025
    41
    Aw no shit? How are these fuckers on YouTube revving the piss out of these motors on the stand? No damn o2s? I knew it had to be something simple. Thanks brother.
    Jan 2025
    41
    Had no idea I couldn’t run it that way. Will unplug o2s to drive it there.
    Jan 2025
    41
    Well with the o2s unplugged it doesn?t want to run at all?
    Indiana
    465
    I've got the same cam in a 4x4 truck, its small enough that it should fire right up and run on the stock tune. I've put the same cam in 2 different builds and both fired right up first try. Might have to put it in OL with the exhaust open like that...
    "It'd be a lot cooler if you did."
    405
    3,249
    If you ran it very long with open exhaust you probably fouled your plugs. O2's don't come into play until it warms up enough to switch to closed loop. Cold start it shouldn't be any different O2s plugged in or not. I think you need to study up on how open/closed loop works with O2 feedback.
    Jan 2025
    41
    Only ran it for 2-3 minutes max, think that?d be enough to foul them and prevent it from idling?
    May 2019
    SE PA
    43
    Do you own a smoke machine?
    Jan 2025
    41
    Quote Originally Posted by Ratssled View Post
    No, what makes you ask?
    Indiana
    465
    A smoke machine to test for vacuum leaks, not to party with lol
