Originally Posted by
Flipper7
Jason, we did edit this with an earlier version of the software to shunt the cat and o2 test during startup, then flashed it back in with Beta. During cold starts with cam, it would run real poor. Popping and hunting, after about 10 seconds it would switch over and run/idle great. Even if I tried to add fuel in the OL tables, manipulate the Vt table to get Ignition timing up during the initial 10 cold startup, no dice. Starts and idles fine when warmed up. After shunting the cat and o2 tests, car cold started perfect. But I'm not sure if something went weird when edited with the early software.
