Results 1 to 2 of 2
Thread: How do you program and adjust after you install a Cam Phaser Limiter ?
    Mar 2022
    Hello , I installed a Cam Phaser limiter in a 2010 5,7 Hemi . What tables do you adjust for the limiter ? Is it Airflow-Variable Camshaft - Exhaust Camshaft ? If it is what parameters do you adjust ? Limiter is a 14* Crank / 7* Cam . I?m sure this is easy but I am new to HP tuning
    Aug 2017
    Quakertown PA
    550
    Yes , Airflow>Variable Camshaft look at Min and Max tables , the WOT is more of a " I have a better understanding I'm ready to F with this table"
    read through this thread , there's some good info in it.
    https://forum.hptuners.com/showthrea...372-Can-timing
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
