Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
Thread: New Code Patch - PATS Disable
  1. #41
    28,768
    Quote Originally Posted by 06TrailblazerSS View Post
    Any update on supporting roush? Sent in 2017 mustang roush file trying disable pats on (swapped into 66 Galaxy).
    Attachment 160180
    Open a support ticket, I'll see what we can do.
  2. #42
    Jun 2018
    Franklin NC
    38
    Sent on 5/7/25.
    I did use method you posted (stock gt file and doing mod andd reloading roush tune). It worked.
  3. #43
    Jun 2025
    7
    mustang gt 2017. Can someone tell why we have only this one in OS directory? “Speed limiter patch”. And only switch PATS D/e in system directory
  4. #44
    Jun 2025
    i am having issue with 2013 ford mustang 5.0L swap on 2003 disable pats with hp tuner but no start no spark or injector pulse any help would be appreciated
  5. #45
    28,768
    Quote Originally Posted by Donjaph1 View Post
    did you apply the patch under the OS tab?
  6. #46
    Jun 2025
    7
    Mustang gt 2017. we apply the patch (strictly according to the instructions), reset the settings in the scanner, change the PATS switch, everything according to the instructions. but PATS DOES NOT DISCONNECT, pcm does not give a command to the starter. When we unload the file after all these actions (we decided to check), in the OS section the PATS patch is shown as "not applied". what could be wrong?
  7. #47
    Jan 2025
    5
    Wondering if anyone has had a chance to get this set up on the tune file I sent in? 2015 fusion 2.5.
    ES7A-12A650-JF
    DG9A-12B684-YA
  8. #48
    Apr 2025
    Hi All, Im very very new to HP Tuners, This is my first time using it.
    I am trying to do a pats delete on a Gen 2 coyote 6r80.
    I was able to apply the OS patch successfully.
    What is the exact process to do the Central Config Reset ?
    Also while the OS patch was wriring at the bottom of the screen it says to change the pats switch...Is this a different process to resetting the central config ? and if so how do I do that also?
    Regards
    Kreasen
  9. #49
    Apr 2025
    Quote Originally Posted by Mike Ushba View Post
    Hi Mike,
    Regards
    Kreasen
  10. #50
    Jun 2025
    7
    Quote Originally Posted by Kreasen View Post
    Hi Mike,
    Regards
    Kreasen
    as you can see, I myself have problems with deleting pats, so I can’t give any confident advice.
  11. #51
    May 2025
    I could use some help with PATS On 2013 Mustang Gt Coyote swap into 68 F100. My stock tune is attached.
    Edit: NM should have read better. Downloaded Beta, applied patch. Worked great. Thanks
  12. #52
    May 2020
    8
    08 F350 PATS Delete needed
    Hey guys im also working no trying to remove the PATS on my truck. I disabled the PATS switch under System but still getting a no start issue. Can you help?
  13. #53
    Jun 2025
    7
    Quote Originally Posted by coosacounty View Post
    You need to apply the patch in the OS section. Use the beta version!
  14. #54
    May 2020
    8
    Just downloaded the new BETA version but in OS i don't have a patch.
  15. #55
    Jun 2025
    7
    maybe this feature is not available for your model year����*♂️
  16. #56
    Oct 2016
    Poland
    2,035
    Not working for every OS out there. Email support, ask for this to be added
  17. #57
    May 2020
    8
    I emailed my file to support and they quickly responded that its not supported yet but would see what they can do. I'm also talking with another HP Tuner guy seeing if i can get it done through him.
  18. #58
    May 2020
    8
    Got my file back and the PATS light flashes but the truck starts. Couldn't be happier
  19. #59
    Jan 2025
    5
    Did support or your guy get it done?
