Results 1 to 8 of 8
Thread: Datalogs post long tube high flow exhaust muffler install
    Nov 2023
    33
    Hello all, my truck was tuned about a month ago and at that time I had not installed the long tubes with high flow exhaust. the following logs are post the LT HFE install. If someone could walk me through the changes that may need to be made, or give me some direction would be greatly appreciated.
    Arizona
    1,291
    Quote Originally Posted by GMTECH704 View Post
    post your tune so we can see it, and help with the changes needed
    Advanced Tuner abc's Avatar
    Jan 2024
    958
    Based on your WBO2, it looks to me like you need to add 3 to 5% starting at 4000 rpm, 90 kpa and up. Post your .HPT file also and lets look at the VE table.
    Nov 2023
    33
    Are you referring to 3-5% 0n fuel or air?
    Here is what you asked for.
    Jan 2024
    958
    Your running lean around the 4,000 rpm point due to the additional flow you received from the exhaust upgrade, which means you need to add fuel to take advantage of the additional airflow. You do this in the VE table and you may need to re-visit the MAF below the PE (power enrichment point).
    Nov 2023
    33
    Thank you for all your help. I will make these changes and log and get back with you
    Nov 2023
    33
    Should I also go into the MAF calibration and add from 8500 hz and up. I am looking at this log were at WOT it commands 11.80 and I'm showing 12.7
    Nov 2023
    33
    From 8500 hrz and above my commanded AFR is 11.8, however I'm only showing that I'm running 12.5.
