Results 1 to 2 of 2
Thread: Low Voltage question
    May 2022
    18
    My voltage at idle is 13.4 and 13.6 while driving. I Didn't know that the gen 4 ls dr44 alternator needs a signal to change the default voltage. My question is, is this too low and will it affect my tune or should I do the gen 3 voltage regulator swap?
    2001 S10 Blazer 2012 5.3 sloppy stage 2 cam. 706 heads oversized valves slightly ported. 4l60e, 2800 stall, 3.42 rear gear
    Advanced Tuner abc's Avatar
    Jan 2024
    943
    Your good at 13.5 volts.
