video only in green
I loaded a new video in Racerender. I made it with DJI mimo action 4, which never gave any problem before, but now the video is only in green color and it ia impossible to see what is shown in the video. I shot this video in MP4, 4K at frame rate 50, width 16:9. Hope someone knows how to cure the problem.
Jan.
Is it possible that your camera is recording with a HVEC/H.265 codec instead of H.264? Your camera might reference that as "compatibility mode" or similar, but a quick look at the specs seems like it should be available for future videos. There's another thread detailing some of the same symptoms here: https://forum.hptuners.com/showthrea...ize-HEVC-codec
If you're able to convert the video to H.264 with Davinci Resolve or FFMpeg as detailed in the other thread, then hopefully you can still use the video. If you need GPS data, then you may need to import the video twice: once with the original file to get GPS and once with the converted file to get video.
