Results 1 to 8 of 8
Thread: 2012 GMC Yukon Denali 6.2 ls Figuring out whats wrong with tune
    Jun 2025
    Tennessee
    New to tuning software instead of hardware. Back story, Had a exhaust manifold snap and cause a knock, replaced it as soon as I got home. A week later a lifter let go. Pulled the heads to replace lifters and cam and do a dod afm delete to find a piston cracked. Pulled engine and rebuilt it.
    Parts replaced as follows.
    Replaced headgaskets with oem thickness
    Replaced all 8 pistons with summit forged pistons, only change was compression height, went from 1.340" to 1.326"
    Replaced oil pump with stock and stock pressure
    Replaced all cam/crank bearings with stock size
    Installed a BTR truck norris cam
    Replaced lifters with non dod lifters.
    Installed a spectre air intake system
    Long tube headers going to 3 inch to an x then back to 3 inch all the way to rear axle
    Got it put together and back in the truck. Started truck after installing engine to be sure of oil pressure, ran and idled for about a minute, all good. Thought the tuning was going to be way over my head so brought it to a tune shop. They hassled me for about 3 weeks and had some issues, some from me and late nights after work installing the engine. Got it all fixed mechanical wise and they started tuning just to find out maf wasnt reading. Maf read before rebuild and nothing wire wise is messed up. Has a code for maf but seems to have gone away. Maf was swapped out with known good maf and still had the same issue of not reading the maf. I finally got the truck to do it myself. Watched all of Goat Rope Garage videos and followed his steps but....
    My issue now is with my wide band reading extremely lean at about 1.56 lambda. Added fuel to idle and did not change. Smoke tested vehicle both hot and cold and no leaks. Below is my tune from after I made a couple changes from the shops tune with Goat Rope Garage advice. Some thing else to add, on the scanner, my maf sensor is reading at or around 3500 hz
    The scanner log was a mistake cant figure out how to get it off my post
    MAF step one.hpt
    Nov 2018
    Middle TN
    97
    Could be trying to do the post cat test, that will draw up your b-hole...
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,256
    Your ECM 4000 maf is failed in the tune.
    Russ Kemp
    5BA8
    5,476
    Russ is a man of few words LOL
    What he means is, your MAF is "failed" which means you're in speed density and it's also the reason for the MAF code.
    In addition, any changes you make to your MAF table will have no affect on the actual fueling.
    Also, your data log is 5 seconds of NOT running.
    email=[email protected]
    Jun 2025
    Tennessee
    Is there any chance you can give me a quick guide on getting it out of tuning on speed density? I've tried looking for the information on the forums but its either getting in to maf tuning, just want to make sure I have everything "turned off" or "turned on" that is necessary for tuning in maf.
    Dec 2005
    Regina, Sask.
    4,256
    I turned the Maf back on.
    Russ Kemp
    Jul 2024
    Pahrump Nv
    22
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Short, direct, informative, and helpful. The perfect reply. ��
    Aug 2019
    Florida
    104
    Russ Kemp
    Morning Russ, sorry to hijack this thread. Can you please free a little your inbox, so I can send you a PM? Or please send me a PM with your email.
    Thanks!
