Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Stock 5.3 with Headers the VE table had to be change by 20+% ???
    Sep 2021
    Kentucky
    1,839
    Attachment 161702
    You've got Flex fuel injector data. I'd bet they aren't flex fuel injectors and this is going to be your root cause.
    That was my thoughts. Having fueling issues but never give a injector part number. Could be the 19lb 99 injectors for all we know. Probably just the standard 25lb set. The file looks like a generic swap tune from a harness supplier.
    Dec 2021
    20
    The file is the stock file, so all the injector data cant be off, The ECM, injectors and intake are all stock I didn't swap them out when I pulled them from the same truck. all of that went from a truck right into the car.
    Dec 2021
    20
    Here is more details
    Engine was pulled from a 2005 Tahoe the full motor with everything on it and the ECM went right into the car I had to get a oil pan and headers so that changed the intake tube wouldn't fit so the MAF is mounted right in front of the intake itself.
    So all the injector data and everything in that file was stock to the ECM, The stock file is the file I posted "G35 First Scan"
    Sep 2021
    Kentucky
    1,839
    Could you still verify part number? Fuel regulator?
    405
    3,214
    05 VIN Z is going to have an in tank regulator with a returnless rail in the stock donor vehicle. If everything was moved over it won't have a regulator on the fuel rail.
  6. #26
    Dec 2021
    20
    Yes it is a returnless set up and I put a adjustable regulator at the tank and ran a return from that back to the tank. so fuel rail only has a supply line.
    I have checked my fuel pressure at the rails at idle still haven't checked under a load, 58psi at idle.
  7. #27
    Sep 2009
    1,148
    Are you sure you have 58 psi fuel pressure? Reason I ask is most Nissan products run at 51 psi. The regulator is internal to the fuel pump and they are returnless. What year is the G35?
    That being said it is entirely possible for headers and full exhaust to require that much more fuel. The engines VE increases a lot when it can breathe.
  8. #28
    North Carolina
    4,829
    Quote Originally Posted by popmods View Post
    Honestly.. kinda pointless to carry on without checking.
  9. #29
    Aug 2016
    Swansea Wales UK
    217
    53 PSI for flex fuel injectors ? i did the same mistake when i fitted an adjustable fuel regulator and it went overboard on the fueling !
    Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
