I have a 2019 L86 with 10 speed 4wd out of an Escalade that was swapped into a Jeep. I removed DOD and VVT utilizing a Texas Speed camshaft (218/230 .610/.610 114+6 10% Fuel Lobe). Intake, bore, and injectors are stock. Running an Aeromotive 340 in the stock Jeep tank with a fuel filter/regulator on the frame (No FPCM). Fabricated 3.5" intake with oil separator plumbed in as well.
I had a tuner provide a base tune to start the truck, and it did. Seemed to idle okay, slight bit of hunting. Actually drove it a few times, and he would update the tune based upon logs I sent. Had good power initially.
From the start, the truck would die at low speeds (less than 10 mph) under part or no throttle. It seemed like after every consecutive drive, log, and updated tune, it ran worse, until now it will start, rough idle, and die after 30-60 seconds.
I have pulled the intake 3 times to verify no leaks at the HP fuel lines or rails, verified there is +/- 59psi at the HP pump demarcation connection, grounds are all tight, and 12v+ from the battery (although voltage does drop a bit until the alternator kicks in).
I am not sure what else to check mechanically that would cause this, so I am hoping there might be something in the tune causing this. I have compared the tune to a 2018 L86 swap that I did a few years ago, and I see nothing glaringly different.
Any help would be appreciated.
Initial tune.hpt
test run 4-30-25.hpl
Latest Tune.hpt
22MAY25.hpl
