Results 1 to 7 of 7
Thread: 4l80 h2 segment swap help
    Jun 2025
    3
    hello im fairly new at this i have a customer that brought me there modified 2006 h2 hummer that is supercharged and has all ready been tuned at some point. the customer had swapped in a 4l80 in the truck and i had installed the swap harness into it and im struggling to find a tune to segment swap the pcm. im hoping someone can point me in the right direction thanks in advance. 06 hummer supercharged white stock file 6.0.hpt
    405
    3,231
    That has had a COS applied to it. You would have to have the original OS file to segment swat a 4L80 segment into it. There are 4L80 segments available for the original OS.
    Jun 2025
    3
    thanks for the info. to help my knowledge what is a COS thanks again.
    Jun 2025
    3
    So upon talking with the customer he purchesed the vehicle modified and has no info on who tuned it in the first place so if i cant get the stock file what do i do at that point ?
    2,788
    One option would be to reprogram the module to stock with TDS outside of HPT. Not saying this is the only option though.
    405
    3,231
    Custom Operating System. With such little knowledge about tuning you should probably just get the adapter that lets you run a 4L80 with 4L60 segments.
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    342
    Here is the file you posted with the transmission and transmission diagnostic segments swapped over to those for a 2006 K2500 HD LQ9 with a 4L80E. I would also internet search the VIN and pull up the sales ad. The ad mentions that the vehicle runs on E85, but the tune is not set up for a flex fuel sensor and the Stoich AFR table is still 14.68 across the board.
