Results 1 to 13 of 13
Thread: 4l80e 1-2 brutal shift
    Jun 2025
    6
    03 chevy silverado SS i segment swapped a 4l80e in.
    3600 stall converter with a transgo HD2 kit, All stock other wise.
    Sent log and talked to transgo tech support because i figured a .100" hole in the (1-2)seperator plate was too big but they believe it is a tune problem commanding crazy high pressure after looking at the log.
    I'm sure the tune is ugly, but was wondering if someone could take a look because i feel like something isnt right on the 1-2 shift. It chirps the tires on a 1/2 throttle and its just a stock lq9 pretty unpleasant.
    North Carolina
    4,836
    The shift pressures are maxed out. My advise would be to start with stock pressure first.
    Dec 2019
    MS
    1,236
    I had a stock 2003 2500HD tune open so i copied over the stock pressures for you to try.
    Jun 2025
    6
    Thank you i will try that and report back.
    5BA8
    5,455
    Even with stock pressure tables it's gonna hit pretty hard with that shift kit.
    email=[email protected]
    Dec 2019
    MS
    1,236
    Especially with a .100 hole in plate and if they used the Transgo accumulator springs.
    Jun 2025
    6
    Transgo told me since the converter is so loose .100 wouldn't be a problem. Talked to a couple guys on other forums they had to go a little smaller with the 1-2 hole though. The other shifts are really nice at .100 just not the 1-2.
    Transgo: "yes it seems to be a tune issue, here’s screenshot of the data where you can see the TSS is not reading (only the 60E has that) , it shows a 3-2 downshift PWM solenoid that does not exist in a 4L80E, and it thinks the lock-up is slipping almost 2000 RPM since the TSS remains at zero all the time when in fact it is locked up solid. You can also see in the red circle I added where the computer is commanding really low amperage (which equals to high pressure) in 1st and 2nd gear up until it is about ready to make the 2-3 shift."
    Jun 2025
    6
    Also thank you RDF1, i didnt realize you put them into my tune been sidetracked with another project i need to try that out asap
    Dec 2019
    MS
    1,236
    So you dont have the TSS connector wired in?
    4L80 has it right above the shifter shaft.
    Jun 2025
    6
    Yes I do, trans is from a 96 if that matters.
    Dec 2019
    MS
    1,236
    Are you sure you have the TSS wired to the PCM correct pins?
    Jun 2025
    6
    I believe i do i followed whatever info online but its been over a year since i did the swap i can verify though, would that effect it?
    Also, i was out on vacation so just drove the truck with the stock pressures. When cold it was pretty good alot less harsh but then once warmed up it was pretty much the same as before maybe slightly less harsh.
    Dec 2019
    MS
    1,236
    Id put a pressure gauge on it to see whats going on now that it has stock pressure settings controlling it.
