Thread: 2009 CTS performance shift parameter
    Is there an adjustable parameter for when the car engages the performance shift mode? I've been trying to find one but I can't.
    Post a tune so we can see. Sport mode may be using "Pattern Y" whereas D may be Pattern X; then you can make changes to the tables of those patterns.
    CTS 3.6 DI RWD performance tune v1.0 (2).hpt
    Here's the file I've been playing around with. I've found out that Normal/pattern X is for drive, Pattern A/pattern X is for cruise control, and Pattern B/pattern Y is sport mode, but I don't see anything specifically for the performance shift mode that gets activated under certain acceleration/braking conditions.
    For the Camaro (see file here https://forum.hptuners.com/showthrea...ng-help-needed) Pattern A is Performance and Pattern B is Trailer. Wonder if you could change one of your patterns to Performance, although the description says that it's not recommended to change, so not sure what could happen...
