Results 1 to 6 of 6
Thread: Air pump issue?
    Jan 2016
    5
    Air pump issue?
    Tune and log attached
    At both 1:12 and 3:37 the air pump turns on and the car appears to leave closed loop but I don't know why. I think it started after I changed the closed loop settings to switch better with the long tube headers. It has only ever happened while cruising in gear, and it seems random but happens pretty regularly now. The pump never comes on otherwise. Does anybody have any ideas?
    The headers don't have provisions for air so the pump is installed but not connected to anything; it just makes loud air pump noises, for what its worth.
    Current.hpt
    air pump.hpl
    Arizona
    1,286
    Quote Originally Posted by saywho331 View Post
    remove pump
    throw in trash ?
    Jan 2016
    5
    That would resolve the noise for sure. I worry that it's just a symptom of something else in this case though.
    Advanced Tuner abc's Avatar
    Jan 2024
    953
    Have you tried unplugging the pump and changing the codes to "NER" and running the same test?
    Jan 2016
    5
    The codes are NER already, but I will try unplugging the pump and logging to see if the car still drops out of CL.
    405
    3,231
    Just pull the fuse.
