Thread: 01 corvette 5.7 dbw mated to 4l80 12221588 0S help
    Put a 5.7 DBW from a 97 corvette IN A 57 Chevy. mated it to a 4l80. Running 12221588 os on a 411 pcm. need help with a transmission segment swap for this setup or another way to run this setup. Was told maybe run 02 camaro, which is an option if someone has one setup with DBW. saw an older post where this setup was done but tune files are long gone. thanksRAY57 no vats.hpt
    Sep 2021
    Kentucky
    1,845
    Write entire with this file. You will need to do the remainder of tuning including shift points.
    so do i buy unlimited credits? how do I license/write this with different operating system and serial number?
    thank you for your help
    Sep 2021
    Kentucky
    1,845
    Just write entire. You will have to license the file as well as the old file.
