Results 1 to 10 of 10
Thread: 2023 Ford F150 need help on fueling
    i am working on 2023 ford f150, i did replace gt500 injectors and high flow cat for my truck. everything else is stock now my short term fuel trim adding lots of fuel and it was lean after max out of learning. do u guy have any guide how to adjust fueling? ty
    pull map again mod 3bar.hptlearning1.hplconfig.Channels.xmllayout.Layout.xml
    Feb 2012
    TEXAS
    642
    Fisrt I would check to make sure all your injector data is correct. Second, Build you a histogram for STFT + LTFT or do each one separate.
    thank you mstang_man. i did injectors from GT500 dial in. now i did open loop tune with my external AEM wideband. all i need to know where should i go to adjust fuel for it when it runs lear or rich.
    should i go to Edit tap and speed density cal then adjust fuel there?
    and how do you create EQ error for every map point? ty
    Jun 2020
    980
    No need to add an external wideband. It has 2 built in; you just have to read them. You logged both, one going lean and one flatlined at 2.00 the entire time. Fuel system is fault status. My guess is when you installed your high flow cats, you damaged the Bank1 O2 sensor or wiring, or didn't plug it in all the way. I wouldn't change anything until that is fixed. I can't tell what your fuel pressure is, but if it's over 65 then the injector data has errors. And where did you get the 3 bar MAP sensor slope and offset?
    engineermike. those info came from 2023 shelby
    Oct 2016
    Poland
    2,034
    Is this truck boosted?
    Your injector data is off. Once corrected, that should improve you fuel trims.
    This is how I dialed in each mapped point. I made a histogram for each mapped point that is being used. At the bottom, I narrowed down the pressure that is being used for each mapped point so I wasn't getting unnecessary information. The 85 under function meant that it will only sample data when its at that mapped point 85-100%. I hope this helps.
    Sep 2022
    Clearwater FL
    435
    So you're correcting fuel trims within each mapped point? How are you doing that? Seems confusing.
    thank you davem3261. do you know how to lock map point? how can i get 10% throttle from close loop to open loop?
