Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Thread: no power at any throttle cammed 4.8
    Arizona
    1,295
    Quote Originally Posted by That_Red_8.1 View Post
    What keep me thinking its a problem like i dont know pcm, electric... rather than tune related is I made a few pull with a 60e unfortunately i dont have log and it was way less fine tune but she was moving especially for a 4.8. i know the 1st gear (3,06) is better in a 60e for a 4.8 i was ready to conceive less accel for way more durability with a 80e with 1st gear (2,48). But now it just pop in the intake and slow as much at high rpm as at low rpm.
    this hurt to read before coffee
    Nov 2023
    15
    Idk what more i can say. It ran like a beast one time even with wrong injector data ripping 2nd gear burnout down to 2500rpm prooving that my setup isnt as bad as you keep saying. Now it pop in the intake and barely move at any rpm or tps from . please guys stop telling i need to buy 5.13 gear and 4000stall converter on a daily to get it move when it already move . i repeat
    -65 psi fuel pressure under load too
    -8x good 38lb injector
    -8x good coil
    -8x new ngk 8mm spark plug
    -8x tr55gp plug
    -2-3% leak on all cylinder
    -180psi of compression on 8
    -new intake gasket no vaccum leak
    -new map, cam, crank, knock sensor
    -good ground and 12v
    -no resistance on any wire on the harness
    Sep 2009
    1,155
    A heavy truck with a loose stall sorta sucks to drive around. I'd find someone else's truck setup like that.. drive it and see if that is something you want.
    I love mine. I would rather have a good converter than deeper gears in a state with 80-85 mph speed limits. Converter can be locked up in 2nd gear at light throttle at 20-25 mph. Converter stalls 3K in my Express van with a 4L85E, 3.73s and 30.5" tall tires. SBC 383 makes ~520 tq @ 3,700 rpm. With a 3K converter, touch the throttle and it gets up and moves for being 7,000 lbs. At light throttle around town it drives almost stock like.
    Sep 2009
    1,155
    -8x good coil
    -8x tr55gp plug
    My 2003 ECSB 5.3L truck needed a 4.30 gear, 3,600 rpm converter on 28" tall drag radials to run strong with the STOCK cam. With the stock converter and 3.42s it was a DOG and it had a 4L60E. It ran like 10.30s with the stock gears, stock converter, and stock rubber. 8.90s with gears, converter and radials. Both times were tuned with thorley tri-ys, 2.5" high flow cats and a 2.5 to single 3" Y-pipe exhaust using a Vibrant merge Y.
    My 2006 Hemi Ram had P305/50R20s that were ~32" tall, 4.56s and a 3,400 rpm converter with a 212/212 @ 0.050 cam to get it rolling smartly. Truck was a DOG with the stock 5.7L, 3.55s and P275/60R20s. I put down 285 whp and 301 wtq with headers and a tune on that truck and it was still a dog. Ran like mid 9s in the 1/8 with the stock cam, converter and gears. Small torque cam, converter and gears knocked a full second off the 1/8 mile. Made like 350 whp and 370 wtq with the cam upgrade.
    Being able to do a burn out with a gutless 4.8L proves nothing except you need better traction.
    You have a BAD mismatch between engine displacement (short stroke & low compression 4.8L has ZERO torque even with the stock camshaft), camshaft timing events, torque converter stall speed, and gearing. True dual 3" exhaust is not helping anything either as it is killing even more low-speed torque due to lack of scavenging.
    There are also atleast 3 different stock stall speeds for a 4L80E. The Big Block/Diesel is like 1,200 rpm. The small block gas unit is like 1,600 rpm. The 4.3L V6 is like 2,000. All numbers above are approximate values behind a stock 4.8Ls torque output.
    I drove a new Uhaul Savana cargo van with a 4.8/4L80E/4.10s years ago. It could not get out of its own way empty and even slight grades had it kicking down to 2nd to hold 70 mph uphill on the interstate. Fully loaded on the way back home it could not even maintain 70 mph uphill and would slow down to 60 mph with a 75 mph run at the hills. Governed at 75 mph or I would have hit the hills even faster at WOT. That driveline was absolutely gutless.
    Arizona
    1,295
    It ran like a beast one time even with wrong injector data ripping 2nd gear burnout down to 2500rpm proving that my setup isnt as bad as you keep saying. Now it pop in the intake and barely move at any rpm
    Ok so reading what you wrote, it ran great before and it had a back fire in the intake and now runs terrible.
    Is this correct to what you are writing down?
    If yes, to me that is not tune related, but something mechanical.
  6. #26
    2,810
    I'm still curious about 65psi fuel pressure on a stock GM regulated setup. If the pump is overloading the regulator to higher pressure than it's supposed to have, that just looks like a problem waiting to happen. Is that not supposed to be a 58psi system?
  7. #27
    Nov 2023
    15
    Quote Originally Posted by bk2life View Post
    its backfiring in the intake under load especially from a dig and absolute no power even at high rpm. No weird noise from the engine; good compression leak test, no ptv, no metal shaving, the cam is still aligned dot to dot. It seem to me to be a pcm problem related to the pcm.
  8. #28
    Dec 2019
    MS
    1,264
    You checked compression on every cylinder?
    Majority of the time backfiring in the intake is either a lean pop or a ignition issue.
  9. #29
    Sep 2009
    1,155
    Quote Originally Posted by RDF1 View Post
    Overlap greatly exacerbates the issue especially with a converter that is too tight and fully loads the engine too early.
  10. #30
    Nov 2023
    15
    yep 180psi on every cylinder before the cam it was 190psi
  11. #31
    Nov 2023
    15
    Quote Originally Posted by Fast4.7 View Post
    i understand but i tried rich or leaner and the popping through the intake is still there and no power that's not normal even at high rpm its slower than before the cam. The acceleration in first with the 4l80 feel like the acceleration in Second from a stop with the 4l60e with same engine configuration.
  12. #32
    Feb 2024
    361
    2.48:1 for first gear of the 4l80e vs 3.06:1 for first gear of the 4l60e, this is significant, and as mentioned above the low torque 4.8L with now more reduced low end torque due to the cam swap, things are starting to make sense. Do you know which converter you used?
  13. #33
    Nov 2023
    15
    Quote Originally Posted by twenglish1 View Post
    i completely agreed i was aware of those gear ratio change but as i mention earlier the in first with the 80e it feel like a dig in second with the 60e it pop through the intake and move like a honda even at high rpm. For now i use the stock converter and tranny. Soon ill install my 80e stage 2 but i wonder if should change my first gear ratio to 2.75
  14. #34
    Feb 2024
    361
    Before worrying so much about the drivability it might make sense to get the everything squared away with the engine side, there has been alot of stuff changed, not everything makes sense, i would put alot of it back to stock, focus on the fueling, then idle. Also which file did you use to swap in your 4l80e segment from?
  15. #35
    Nov 2023
    15
    From a silverado 6.0 2500 00 i think
  16. #36
    Nov 2023
    15
    it idle super great cold or warm like stock even the startup smell fuel but its dialed in for narrow band considering i dont have cat on it. i change the necessary setting for cam like VE, fuel injector data, idle airflow, torque management, trans setting
