Results 1 to 15 of 15
Thread: 6L80E Trans Torque Management - How to Reduce Duration of Timing Profile?
    Can someone lead me in the right direction. I have done my due diligence with the search feature but unable to find specific answers.
    I am noticing on my logs (profile as reflected on my chart) the duration of time from when my timing starts to be pulled and when it recovers is taking longer than desired.
    I know there may be several tables that effects the timing profile but would like some help on identifying which tables would have the greatest effect in reducing this "timing pull duration" Specifically when it starts its ramp, how long it stays at the min set timing and when it ramps back out.
    This is a fully built 6L80e with an E38 and all hard parts currently available and approx. 900 + rwhp.
    I do believe the use some torque management is necessary to make the trans live under abuse and know the 6L80e can handle a lot more power than many believe. But the tune is and always has been the key to survival.
    2011 Camaro, 430cu Lsx, Mast Heads, Ported TVS 2300, ID 1300's, E85-Flex, Squash Fuel System, 250 Direct Port Nitrous, LPE Overdrive rear 10/14 Rib, Overdrive, 2.8" Upper, NW 102, 2" ARH, PATC built A6, Circle D Conv. etc. BMR 15" Wheel Conversion w/29/10.5W's/15 Hoosiers
    2007 H2 SUT, 427 LSX, T76 BB@16lbs 225 Trickflows, Vic JR Intake, Lt's, Dual return fuel sys, Comp 236-232-115, 4L80e, 3000 Vigilante, etc.
    North Carolina
    4,861
    What is the commanded shift time during this?
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,132
    Quote Originally Posted by DRTWRK View Post
    Hard to say without a tune and log file. The commanded shift time is a big part of this, but other things are happening as well (ie disengaging the TCC, filling clutch solenoids, etc).
    You may find some relief in changing the field [TCM] 484 - Speed Control Termination Mode to Immediate. Otherwise, if you have it on a ramp setting there will be additional delay during the ramp down and up process. Additionally, what may LOOK like a long ramp can also be caused by a slow polling rate for the channel data. If you really want to get better timing data, remove as many channels from the log and set the polling interval to 10ms to isolate the event.
    Aside from the data in the log file, what is the human experience like? Are you noticing any actual drivability/performance issues?
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Thanks Guys
    I've been a member here for about 15 years but seldom make post or send attachments. It seems I can attach the .hpt file but not the .hpl
    My .hpl log will show the extended timing pull that allows the engine to fall on its face due to the timing being pulled dwn to around 3 degrees before the shift completes. The 3 degrees is what I have in the Min Timing Torque Management but in the past has not pulled the timing long enough to feel the power loss.
    Probably need a little help with this also.
    Aug 2021
    1,132
    Is it happening for all gears? Just looking at the 2-3 shift times ([TCM] 15712) it does not follow the gist of the other shifts.
    MAF Assistant
    EOIT Assistant
    Recently, I've only noticed it between 3-4 at full throttle using TUTD. I have my shifts set while in TUTD to auto shift at a certain rpm.
    If I can attach my latest log, you can easily see my problem but for some reason, I'm unable to.
    When I use the TUTD to initiate shift prior to my preset auto shift speed the timing immediately drops to the 3* Min Spark>Torque Management setting as it is supposed to, but it remains there for a half second or so, sufficient to make a very noticeable power drop before completing the shift. I'm trying to identify which settings that control the duration in time that timing is being pulled.
    The current tune is one that I have used for years, and the trans has been very reliable.
    I have recently increased my injectors from ID 1300 to ID 1700's and have touched up my Virtual Torque Tables but not changed them enough to think they are the problem.
    I just took a screen shot and probably no help but it's not letting me download the actual log
    Aug 2021
    1,132
    The first 3-4 shift at WOT is funky. This has to do with the solenoids powering down and fluid draining out. So the first shift takes extra time to fill it back up with fluid, then all subsequent shifts are normal. So you can test this by ensure you shift into 4th before your first WOT pull.
    However, if this happens all the time, then it is something else.
    What I see is that your standard automatic Drive selection uses Pattern X ([TCM] 462 - Pressure Pattern Select) and Pattern X is mapped to Normal Mode ([TCM] 468 - Control Mode) while your TUTD is using Pattern Z ([TCM] 465 & 466) which is mapped to Special mode ([TCM] 470 - Control Mode). And all your Pattern X & Special modes are different than your Pattern X & Special settings. So if the car shifts fine in Drive but not TUTD, this is your problem, just synch the settings, there are quite a few (or just make the TUTD section use X and Normal to test).
    May be a few other places, but these are the main ones:
    Shift Pressures > Upshift has pattern X, Y, and Z definitions.
    Shift Pressures > Adaptive has definitions for SP (special) settings
    Shift Timing > Upshift has definitions for Special
    Personally I use X & Normal for everything, so Drive = TUTD and all settings stay in synch which each other. And I only have to change things in one spot, which then applies to everything.
    MAF Assistant
    EOIT Assistant
    I use TUTD for all driving. I will sometimes make a hit without revving to the upper rpm that it will auto shift for me. (Short shift) The screen shot is from a short shift but using TUTD paddles.
    Generally, the shape of the timing curve is more of a V shape and not the long duration of timing pull the screen shot reflects.
    Finally able to upload a log.
    Look at the time at 10:04:466-time, shift is between 3rd and 4th.
    My concern is the time duration of torque management and how to reduce this duration. It appears my 1-2 and 2-3 shifts are both normal to me and do not reflect this extended timing reduction period.
    Aug 2021
    1,132
    Can you upload the stock tune file?
    MAF Assistant
    EOIT Assistant
    Cringer I will try.
    Attached should be the factory tune. There have been 4 engines and several Transmission rebuilt since this car first hit the streets 14 years ago, I had the original engine removed with only 134 miles on new car and replaced with a Mast 416 for my first build.
    I have used the same trans shop to build my transmissions and have had very good service from the builds. Lots of abuse running full time Hoosier 29-10.5 W's Slicks and to my knowledge every available aftermarket hard part for durability has been incorporated. I have stair stepped in horsepower that started with ID 850,s, ID 1000's, ID 1300's and now ID 1700's with lots of nitrous.
    This build has a few years on it, but I don't drive it much only on Friday and Saturday nights.
    I performed all my own trans tuning and have really benefitted from many contributors from this forum through the years. Convertors failing have been my main cause of rebuilds. I have been told from my builder the clutches and overall components have all looked good for the abuse and miles. It's been a few years and was told he has since passed away.
    Aug 2021
    1,132
    Cringer I will try.
    In comparing the stock to your current tune...
    This section is zero'd out in the OEM tune. I would start there (returning it to stock).
    I would also return these back to stock
    Then I would reset the trans additives in the scanner and slowly drive around and allow the trans to relearn before beating on it.
    MAF Assistant
    EOIT Assistant
    Nov 2018
    Middle TN
    97
    The torque Factor tables have always determined the "pulse width" of the timing pull on mine. I noticed watching the logs as I lowered those the duration would get shorter.
