Results 1 to 5 of 5
Thread: FTI triple disc converter questions
    Sep 2021
    Lexington KY
    329
    I put a 2800 stall 9.5 inch triple disc FTI in my Silverados 6L80 back in Feb of this year. Noticed fluid coming out of the inspection cover recently. I test fit it before reinstalling the trans. It seemed to engage the pilot hole in crank and was flat against flexplate. But Im wondering if I shouldve used the spacer that comes with it? Anyone else had this happen? Its either the converter leaking, bad new fluid seal or converter isnt engaged all the way. Just wondering if anyone else has experienced this. I build transmissions for GM and never had a fluid seal leak thats new, esp on a 6L. But I know anything is possible. Gonna take it out next weekend and look. Hoping someone with a FTI or Circle D can help! thanks.
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,127
    Did you measure the endplay between the converter and flexplate? Should be 3/8", that is what the shims are for as it allows for growth when things get hot. Did you lube the converter snout inside and out so it didn't tear the o-rings in the trans?
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Sep 2021
    Lexington KY
    329
    Yes to both. I put trans gel on the converter and turbine shaft seal. I had put fresh fluid on the o-rings. the gap looked right before I bolted it up. Looked like the stock converter gap. I also set it up on the flex plate before installing. It was flush on the flexplate and the hub looked to be in the pilot hole of crank. Im hoping its just a bad new fluid seal. But I have read that FTI has had some issues with their welds lately, so who knows. Bout ready to just put a ZL1 converter in it again and say heck with it. lol
    Apr 2024
    13
    We recently installed a FTI 9.5" Triple Disc 3600 in my sons 2010 Camaro SS with the 6L90 trans. We had to use the spacer / adaptor that came with the converter as the snout on the converter was smaller OD than the ID of crankshaft. We had just over 1/8" endplay between converter and flexplate. Lately I've seen several people say they must have 3/8" but FTI, BTE, and Circle Ds instructions all say 1/8'' to 3/16'' ???
    Sep 2021
    Lexington KY
    329
    As long as its not leaking Id say youre good. Im going to take mine out this weekend and check the seal. If thats not leaking and the welds are good on the converter, Im gonna put the spacer on and see if that cures it. It doesnt leak alot, like blowing all over the bottom of the truck etc. just a few drips here and there. Thats what is so puzzling.
