Results 1 to 8 of 8
Thread: 6l90 TCC apply ramp strategy. ECCC
    Mar 2016
    Connecticut
    29
    Vehicle in question: 2011 Silverado 2500, 6.0 gas, 6l90 trans
    For years I have been trying to solve a hesitation/chuggle/choppy acceleration issue with this truck (in fairness I go through spats of obsessing over it to not thinking about it for 6-12 months). Maybe this is old news for most of you, but let me post a little bit of what I have learned over the years of playing around with this... hopefully for the benefit of someone out there.
    The sensation that has bothered me so much all comes down to the TCC lockup strategy used in this truck. Which is an ECCC lockup strategy (Electronically Controlled Capacity Clutch), where the toque converter does not completely lock up at all. Instead is it set to a constant slip of 20 rpm (in this particular vehicle). And that is done to reduce harsh drive line sensations and temporarily broaden the gear ratios (the ability to control slip is also used in the actual shift process allowing the use of inertia to smooth out clutch to clutch transitions). However, the system is not really able to "hold" the slip to 20 rpm, instead it uses pulse width modulation (pulsing the fluid pressure on the TCC) to attempt to maintain 20 rpm. As the slip deviates from 20, for example when the throttle is increases, the TCM increases the pressure and/or pulsing to bring the slip back to 20.
    The issue that I have is when the TCC slips well past 20, which is common under load, the rate at which the pressure is increased to bring the slip back to 20 creates a jerking affect and often resonates like a spring, jerking all the way through a moderate acceleration. This is most noticeable from about 1200-1800 rpm. To resolve the issue, I have reduce the desired slip to 10 rpm in 3-6th gear and increased the + side of the apply ramp table by about 10% across the board and up to 30% in the slip rpm of 2-12. Currently the vehicle is much better to drive.
    It seems there is a different strategy for almost every different vehicle out there. Some people seem to think that you want to keep the torque converted unlocked for most of the gears only locking at cruise and higher speed and others seem to think locked. I do notice in the full throttle TCC tables of my truck that the lock speed is 6mph for all gears (meaning at full throttle the torque converter is locked on whatever the desired slip tables are programmed for). Corvettes seem to use a 0 rpm desired slip for most gears, and Camero's used 0 rpm for the 1st gear or two, then more slip on the higher gears. I guess what I am suggesting here is that with so much variation in strategies in vehicles, it has to be less about longevity and reliability and more about the feel / performance.
    Now here is the real question.... In my quest to reduce the "spring" like action of my torque converter bouncing back to the desired slip I have spent a lot of time pondering the curve of the TCC apply pressure ramp. There are 3 options for this curve: Linear curve - basically a straight line increase of pressure with slip. Exponential curve - where pressure rate of increases is more and more with more slip. and Cubic where the rate of increase in pressure is less and less with more slip. It would appear looking at the stock tables, that the factory curve was cubic - where they start off aggressive with 2-12 rpm of slip and although the pressures are still increasing with more slip, they are not increasing at as fast a rate as the slip continues. I would be very interested to see if this curve is the same with other chevy vehicles ? or any other vehicles for that matter.
    The other item that I am not 100% comfortable with is the Regulator Offset, which has been described and the min pressure in the TCC regulator circuit. The stock setting on this is 26.69 psi. What i am unclear about is why such an odd number and how does that interact with the desired slip tables.? That number was picked for a reason...... ? So if the slip tables are changed, the min pressure should probably change with it? (or visa versa )
    I am also still trying to find out what the TCC adapt is...?
    I find myself raising the regulator offset values from 26.69 to 60-80psi with aftermarket converters.
    Stock converter I don't mind it at all
    Mar 2016
    Connecticut
    29
    I should also add that when trying to figure this out, one of the first things I did was lock up the TCC and I still had a hesitation/skip so I ignored the TCC tuning for years. It turns out that I did in fact have a misfire on cylinder 1 - which did not register enough to throw a code. I finally logged misfires from individual cylinders and saw the misfire. After replacing the spark plug wires, plugs, and the injector. I still had the misfire. It was the spark plug wire from number one cylinder arcing over to a thin aluminum heat shield protecting a sensor. OEM wires and Taylor high performance wires both arc'd to this heat shield. (my guess is that the hollow round shape of the heat shield somehow created a high negative potential - Like those domes they use to make an large arc for demonstrations). Simply spacing the wire from the heat shield solved this problem and then I was able to figure out the trans / TCC tuning. It was a little difficult with two types of hesitation that felt very similar.
    Oct 2008
    Mebane NC
    477
    Try reading this https://forum.hptuners.com/showthrea...ly-Issue-Fixed!!!.
    La RPM I changed mine as well, went to 90 and changed the gain to 1.5. Converter locks up like a another gear
    Quote Originally Posted by DrLoch View Post
    if only they would implement that table on 2014-2015 trucks
    Oct 2013
    548
    Quote Originally Posted by La RPM View Post
    The TCC regulator gain, and TCC regulator offset, are single parameters - not a table.
    These no longer exist in the 2014+ light duty truck 6L80 (T43) TCM calibrations - these are simply gone - so there is no way for the software engineers at HPT to implement these previously available parameters, into their software.
    It seems that GM made changes to the T43 calibrations, when mated with the E92 ECM.
    There may be another (yet undiscovered) means of achieving the same (or similar) effect.
    For now, the only T43 calibrations that have these parameters available are: 2006 to 2013 Corvette, 2007 to 2013 light duty truck, 2008 and 2009 G8, 2010 to 2015 Camaro, and 2009 to 2015 CTS-V.
    Aug 2019
    Quote Originally Posted by Jon S. View Post
    Any update on this? I have a 2014 GM truck that has converter slip and could use the TCC regulator gain and TCC regulator offset.
    Nov 2018
    Maryland
    Digging up an old thread here, but I'm having the same jerking/surging issue on my 2016 Silverado 2500, and trying to make some adjustments. For a bit of background... I recently replaced the trans after the stock TC ate itself, and I opted for a billet cover on the new TC. That may or may not have any impact on the issue, but noting the fact that it is an "aftermarket" converter.
    The jerking is most noticeable in 3rd gear between 2000-2500 rpm, and in particular when towing my 5th wheel trailer. I've confirmed the pulsing TCC slip amount via data log, and there is -7 to 7 rpm up/down on the TCC slip. That's not towing anything, and it's still somewhat noticeable. The same condition when towing can be borderline violent in the truck. Feels like a bad misfire. I'm assuming this amount of slip pulsing is more noticeable with the billet converter vs stock.
    - TCC Slip is set to 20 rpm in all gears except for highest torque value (158.58) which is set to 10 rpm.
    - TCC regulator gain: 0.375
    - TCC regulator offset: 184 kpa
    Judging by this older post, limiting the TCC Slip to 10 rpm, and adjusting the apply ramp should help. What I'm not sure about is the regulator gain and regulator offset. Should I make changes there as well.
    Any help/guidance is much appreciated.
    Thanks!
