Results 1 to 13 of 13
Thread: 4.8 Hot Start and Fuel Trims / VVE
    Tuner in Training DanN's Avatar
    Jul 2019
    Shuswap, BC, Canada
    41
    Losing my marbles a tiny bit. I've been chasing my tail for quite a while now, and I think I must be missing something basic.
    I have a 4.8 with the "low buck truck" cam: Lift .552/.552, Dur @.050 212/22X, LSA 107 Deg. I have a TBSS intake with the flex fuel injectors.
    I have reverted to my starting point, and have attached it with a basic idle log and a hot start log.
    I have been trying to follow Cringer's method, but my LTFT and my charts don't seem to jive.
    I am logging lambda from the AC input with this math: ((([7101.10]/0.5)+10)/14.7)
    I could use a leg up.. feeling pretty defeated at the moment.
    1972 Triumph Spitfire Ecotec Swap:
    Stage 1: MEFI-4B & L61 - deceased; ate it's own balance shafts - because I did a dumb.
    Stage 2: E37 & GenII L61 - Ran great, but too meh.
    Stage 3: An LSJ is a good time in a 2000# car.
    2005 GMC Canyon base work truck.
    LS Swap, AR5 Trans, BCM transplant, Sierra Dash, G80
    Aug 2021
    1,126
    I'd get the part number off of the injectors and make sure you have the correct data in the tune for the injectors you have. Have you done any VVE tuning yet?
    Jul 2019
    Shuswap, BC, Canada
    41
    Quote Originally Posted by LS ROB View Post
    Just checked my Injector data - it got changed somewhere along the line. Updating...
    Haven't tried VVE tuning. Call me chicken. Ha.
    Jul 2019
    Shuswap, BC, Canada
    41
    Updated tune with corrected injector data, and a quick around the block log. It is definitely better.
    I'm reluctant to fiddle with the VVE table until I'm a little more confident my data isn't garbage.
    Dec 2019
    MS
    1,240
    Whats your injector part number?
    Aug 2021
    1,126
    Add cylinder airmass to your channels.
    Jul 2019
    Shuswap, BC, Canada
    41
    Quote Originally Posted by RDF1 View Post
    They are 12594512, which are listed as 38# for a 5.3 w/ flex fuel.
    Will do.
    Jul 2019
    Shuswap, BC, Canada
    41
    Fresh copies of the tune and log.
    Dec 2019
    MS
    1,240
    Quote Originally Posted by DanN View Post
    Will do.
    Here is LMG injector data.
    Jul 2019
    Shuswap, BC, Canada
    41
    MANY thanks RDF1.
    Here is the latest tune and log. I have updated to the LMG injector data and made a small tweak to the MAF tune.
    Jul 2019
    Shuswap, BC, Canada
    41
    Still working on this with limited.. success?
    At one point I thought I had it, but it seems I don't. My hot start is over 5 seconds (no throttle input).
    I tried some suggestions from Cringer's Youtube for the Cranking VE vs Map vs RPM and Idle Startup airflow vs Run time (off time) vs ECT. It seemed to work the one time I forgot to log, but not so much since.
    I also did a little dabbling in the VVE.
    Seems it needs more fuel on cranking?
    Aug 2021
    1,126
    Give this a go to see if it helps at all. If it starts, let it idle for a good while.
    DN_9_July_4800_Startup-3-idle-airflowrobtest.hpt
    Jul 2019
    Shuswap, BC, Canada
    41
    It did start; I let it idle for a full 10 minutes. Then I stopped it and restarted, and logged another 3 minutes. The restart was quite good I'd say.
    So..all you did was set Final Idle Airflow Min vs RPM vs Gear back to stock. I didn't think that would really matter given it's a manual with no gear feedback...
