Results 1 to 11 of 11
Thread: New to all this. 99 ls1 upgrades need more help
    Apr 2025
    3
    I have a 1999 ls1. Was all stock.
    Swapped into a 1987 camaro. Had some pcm changes 10 years ago. Shut off VATs, post Os, EGR other small stuff.
    I put on a bigger intake (generic high rise) 102mm throttle body, 54lb injectors and swapped a MAF (card style 12576410) I got the IAT figured out and adjusted. No MAF reading on scanner and it over fuels and stall the engine e out.
    Can someone tell me just how bad I messed up.
    I shut coded p0101 p0102 p0103 off and still over fuels.
    Oct 2004
    691
    My psychic is off work this weekend, so I have no idea what your tune or log files look like.
    Arizona
    1,287
    Quote Originally Posted by RkgLS1 View Post
    you didnt post your tune nor your log, how can we see anything?
    The following list really helps us, help you:
    Vehicle make/model/year
    Tune AND data log
    Engine/size
    Axle gear ratio / tire size
    Computer and operating system used
    Type of heads (317/243)
    Transmission
    Torque convertor stall
    intake manifold
    Intake tube / air filter
    MAP part number
    MAF part number
    Injector part number
    cam used (link to specs)
    exhaust type (long tube headers, no cats, straight piped)
    pictures of engine
    pistons
    compression
    throttle body type, size and DBW/DBC
    Fuel pressure at idle and while driving
    fuel system type, FPR, pump size, returnless or no
    ect ect
    Apr 2025
    3
    first thing is I want to thank you to anyone being helpful.
    this is just a fun cheep build to start with.
    I will try and get a data log tomorrow.
    motor and trans are out of a stock 1999 pontiac firebird 5.7 LS1 stock rotating assembly
    2g2fv22g2x2203616
    hardware p01 gm gen3 v8 4.3 v6
    S\N 1dg01em28252
    operating system 9373372
    3.43 gear
    245/50r16 tires
    853 stock heads
    4l60e stock
    102mm throttle body DBC (amazon cheep)
    12609749 (6.2L 2013 yukon)
    MAF 12576410
    MAP stock ls1
    4 inch air intake pipe to non-oiled cone filter
    stock manifolds to 2 1/4 ypipe no cats 3 inch cat back
    stock camshaft
    stock Narrow band O2
    return fuel system
    fuel pump out of a 2007 silverado.
    cannot drive to get fuel pressure.
    Oct 2004
    691
    So you put in injectors that are almost twice the flow rate of stock, but did not change your injector data. No wonder it floods out. There will be lots of other issues, but that is the first most basic one that must be dealt with.
    Apr 2025
    3
    55 psi at idle
    48 psi at 2500 rpm
    no driving psi
    Dec 2019
    MS
    1,252
    Assuming you have the regulator connected to a vacuum source..
    Here is the injector data for that. As well as IAT correction for card maf.
    Arizona
    1,287
    Quote Originally Posted by RDF1 View Post
    what was changed for that?
    i ask because i have a card maf im installing into a swap where a normal MAF wont fit.
    im just curious as what 'correction' was made as i have done some research and saw id have to make the entire scale myself through trial and error.
    Dec 2019
    MS
    1,252
    Quote Originally Posted by bk2life View Post
    The scaling is different.
    5BA8
    5,473
    Quote Originally Posted by gametech View Post
    Sorry I'm late.....
    You can borrow this ^^^ LOL
    email=[email protected]
    Oct 2004
    691
    Sorry I'm late.....
    No offense, but I'm more of a magic 8 ball guy, lol.
