First time diving into HP Tuners, but I have looked around pretty significantly and made adjustments based on what I have read in the forums and help guides. I mainly focused on MAF calibration due to a CAI and no cats and the power enrichment adjustment tables. I have datalog before and after making the changes, and it seems like I am getting spark knock anytime I make changes in the PE area. I am running stock timing and only added fuel in the EQ Ratio table. I have run 93 octane and even octane boost and still seem to get the knock around the same spot. I though that it wasn't real, but it seems like if I go back to stock tune I don't knock at all (maybe due to PE never kicking in)? I do have a broken exhaust manifold bolt, but I assumed that it would knock all the time independent of tune if that was causing an issue. I also tried to tune out burst knock and reduce the KS sensitivities (not sure if I got those right).
Any chance that I could get someone to look over my tune/ logs and see if I am just missing something, or if I made too drastic of changes?
It is a 2005 Chevy 2500 with a LQ4 and a 4L80e.
after maf and ks adj.hpl2005 Chevy Truck MAF cal with PE and BK adjusted.hpt
