Results 1 to 7 of 7
Thread: Long term Trim vs AFR Error table
    May 2025
    13
    I'm trying to understand if I have a problem. I Look at my long term trims and they are showing +20 across the board which would make me think I'm running way too lean, but the log of my AFR error table the table looks pretty good overall. Not perfect but not too lean like the LT is I think is showing. As I go down this path of learning I don't want to lean this motor out and cause issues. Are my Long term trims incorrect... Should I be adding fuel on my my VE table to correct this? I'm assuming the PCM is correcting for this Mis-balance like it should and I just need to work on the VE table to make this correction on Long term trims not so high?
    Just learning... log file attached.. Any advice is appreciated
    Using a AME 30-300 wide band
    Car spec's
    Ls 6.0
    BT Stage 2 Cam cam Specs: 227/238 .620"/.605" 113.5+2.5 #32738132R0
    799 heads
    AF10043 MAF SENSOR
    AFS123 O2 sensors
    02 Truck manifold with #25317628 injectors
    Vacuum referenced regulator (fuel rail mounted old style)
    4l80E
    102mm throttle body (it was free I know it?s too big)
    DURALAST AC162 IAC SENSOR
    TH149 TPS SENSOR
    P01 PCM 12208322 OS.
    Arizona
    1,281
    post your tune as well.
    log shows 50% of the issue and the tune sows the other 50%
    May 2025
    13
    Quote Originally Posted by bk2life View Post
    Here is the tune
    Oct 2004
    682
    If you run closed loop, the fuel corrections do exactly what they say, so your wideband should show pretty close to stoich. If you go into PE, which takes you out of closed loop correction, the problems will show up on the wideband. So yes, correct the fuel trim error.
    Feb 2024
    353
    Assuming your injector data (I didn't check) and your fuel pressure is correct (You need to check), the injector data is at least set up for a referenced regulator so this is a good start, looks like it just needs tuned, trims are adding a ton of fuel across the board, try to fail the MAF, under engine diag tab, set the DTCs to MIL on first for the 3 MAF codes, set the MAF high frequency fail to 0, and under engine tab set Airflow>Dynamic>High RPM Disable to 8000 or something high, this will force SD airflow mode with closed loop O2 feedback, maybe start by adding 10% to the entire VE table and see how it responds, but only do this after you verify fuel pressure and injector data! Also be sure to clear LTFTs with the bi-directional functions in VCM scanner before logging again every time changes are made.
    May 2025
    13
    I will try this. Thank you for you feedback.
    Feb 2024
    353
    You should also disable DFCO as well as it can skew data, Engine>Fuel>Cutoff, DFCO>Enable ECT set to 284, I don't think this will have much of an effect on the fuel trims, but when you use the wideband for WOT adjustments you will get lean spikes when fuel injectors are shut off during deceleration
