I recently bought a 2006 2500HD with 190k, LQ4/4L80E, 4.10s, and 32" tires that felt much slower than I expected, so I jumped into some basic mods right away. While it does feel a bit faster now, I don't think it's right. Judging by the Delivered Engine Torque PID, I'm barely making factory power (340ish at most). Compression is even, with about 8% total variance.
The truck came with a Spectre CAI and a non-aggressive aftermarket muffler, then I added a TBSS intake manifold w/ 36 lb injectors (retained the factory throttle body), and a TN/Low Buck Truck cam with LS6 style springs. The tune is pretty dialed, from what I can tell. I just changed to the LQ9 high octane spark table today (with more added at idle due to the cam) to see if I was just missing a bit of timing, and it seemed to make a slight positive difference in around town responsiveness, the truck still feels pretty slow and doesn't make any more max power. I have not been to a dyno, just street tuning myself. I do have a WB O2 in Bank 1.
PE has been changed, per usual. Injectors aren't anywhere near maxxed out, even with it going fairly rich up top. I have not verified the fuel pressure (have a new pump on the way, just to rule it out...because 190k...), but it is not going lean at all. Hardly ever sees KR, though it has some at low RPM/medium load knock with the LQ9 spark table that is never present with the LQ4 table. Running 87 octane.
Is this truck just that slow? Should I be making more power? I have a feeling that a converter and 4.56s are in my future, which I'm OK with...but I do want to make sure that the truck is in good working order first. A second set of eyes and some experience would be greatly appreciated.
Drive_20250706.hpl
WOT_20250706.hpl
20250706_LQ9 HiOct-LQ4 LoOct.hpt
