Results 1 to 2 of 2
Thread: Chopocabra Cam and Brake Booster issues
    May 2023
    Grand Blanc, MI
    26
    Scratching my head with this one good people... 2007 Avalanche, 5.3, fresh engine rebuild, Chopocabra Cam. Having braking issues. Not sure if its something in my tune, or if I'm battling a mechanical issue. So far, Ive changed the brake booster with a known good one, changed the check valve, new AC Delco MAP sensor. Vacuum is a bit lower than Id like to see, but I don't think its so far out of spec to cause the pedal to be this hard. Looking to see if perhaps I need to run an aftermarket vacuum pump, or am I missing something. Posting the most recent log with all the mechanical parts replaced. Any insight would be great!
    5BA8
    5,476
    That should be plenty of vacuum to run your brake booster.
    Looks like you have a miss on bank 2.
    email=[email protected]
