Being fairly new to HPTuners, I'm looking for some input on how best to connect a PLX SM-AFR Wideband to the Prolink+ Cable on my MPVI3 and set it up properly in VCM Scanner.
My understanding from researching is that the 0-5V wideband output from the PLX should be connected to the red wire on the Prolink+ cable.
If that's correct, what is the best way to setup it up in VCM scanner for logging and make sure the math (AF Ratio = 2 * Voltage +10) is correct?
PLX SM-AFR Info:
https://www.plxdevices.com/Wideband-...7346002726.htm
Bosch LSU 4.2 Sensor
0-5V Wideband Output
