Results 1 to 8 of 8
Thread: need help with dynamic air tuning
    Sep 2018
    Aumsville,OR
    10
    truck set up
    07 silverado
    l33 5.3 4l65e 4x4
    dod delete
    ls7 lifters
    btr truck norris cam
    hardened push rods
    new head gaskets
    580 lift spring
    lt headers
    no cats
    2.5 exhaust pipe
    x pipe dual in dual out muffler
    rest stock
    tuning myself ive done lots of reading and bought books and really have put the hrs in over years of learning tuning by no means a pro but not a noob either ive tuned lots of gen3 trucks and subaru's on many platforms like holley and haltech motec megasquirt hydra etc. watched all the silver surfer vids and read lots on here but i've hit a wall that i cant seem to brake through. so got the truck to start idle and drive decent but when tuning dynamic air style for the maf and vve together things dont lay out correctly with the fuel trims its always telling me i need to put a bunch out down low and the fuel trims say im within 2 to 3 percent and if i use the number im getting with dynamic air it messes everything up so bad the truck has no power and will barley run and i have to start over. so asking for help in anyway to point me in the right direction thanks brandon ancona
    Advanced Tuner biholliday's Avatar
    Nov 2020
    Kingman AZ
    211
    after you make a change to fueling are you resetting your trims in the scanner? are you allowing for the rich after reflash condition? i tuned my maf and vve tables seperately then put it back in blended and the 3 reading are almost the same. mass airflow dynamic airflow and volumetric efficiency. if you are using cringers tuning tools your tune will be spot on.
    Sep 2018
    Aumsville,OR
    10
    Quote Originally Posted by biholliday View Post
    yes im resetting the fuel trims every time im allowing time for fuel trims to even out after reflash i do a dummy log till they mellow out then i take a real log and yes im using the tools i know there supposed to be spot on but there not im not tuning them one at a time im doing both like he says to and the number dont lie it says my dynamic is off by -25 but fuel trims are with in 2 percent
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,131
    Quote Originally Posted by banconas105.3 View Post
    Your MAF is really close. VVE is still quite rich. The good news is that your VVE shape is really well done. No harsh zone transitions and overall very smooth.
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Sep 2018
    Aumsville,OR
    10
    Cringer thanks for the reply i could really use ur help. ok so ive gotten the maf that close but not with the dynamic air math in the scanner ive been using ltft+stft and then inputting that into the maf tool you created because if i use the dynamic math everything gets leaned out so much truck will barley run idk what the hell is up but ive watched all ur videos over and over checked the math and filters and still i get the same results its totally frustrating ca u look and see if anything stands out in the tune or the scanner i have been doing pe stuff cause if i cant get cl right i dont wanna try pe one time i did it was super lean and lean popped on me. heres my most recent log and tune. also ive been inputting the new histrogram and the vve table and pasting it in to your tool every time after i flash is that correct? and ive tried to uses ur eoit tool also and i cant seem to figure that out but thats a whole other thing ill tackle after this any help u can provide or any knowledge you can share is much appreciated thanks Brandon Ancona
    Sep 2018
    Aumsville,OR
    10
    Cringer idk what the h@^L im doing wrong but ive done a couple logs and adjusted my vve table with your tool and each time vve just keeps getting worse and worse its really bad now and the truck wants to die when it comes to an idle and then catches itself and bucks and coughs and its way down on powder wont hardly get out of its own way. plus it just sounds awful and knocks also noticed my short fuel trims bounce like crazy and i can feel when it adds fuel and takes it away im at a loss about to flash it back to stock and start over idk please need some guidance is there a table that needs to be zeroed out that i missed maybe something with dod? ive notice my spark table is super jagged everywhere when its shouldn't be. anyways HELP ME
    Obi-Wan Kenobi YOUR MY ONLY HOPE LOL... THANKS BRANDON ANCONA
    Aug 2015
    18
    Looks like maybe you're editing the VVE table for "manifold switch closed" when you should be editing "manifold switch open". Or just copy/paste all 4 so they're the same. It references the "open" table though.
    Its also not entering PE. 12420 needs to be around 15-18 to get PE to activate at 40-50% throttle.
    Tuner in Training fourninesfine's Avatar
    Dec 2023
    Upper Michigan
    37
    You may need to tune MAF and VVE separately. Here's a base file and some useful channels to get you on your way.
    2007 Chevolet Silverado 5.3 Truck Norris 002 - Base Tune.hpt
    E67_All.Channels.xml
    2010 Cadillac CTS-V (LSA/6L90E, E67/T43) - 211/230/122.5 .562/.562 camshaft (stock LS9 cam), 2.55" pulley, solid isolator, Airaid intake, ID1050X injectors, reinforced intercooler, C&R heat exchanger, EOS test pipes.
    2005 Cadillac Escalade ESV (LQ9/4L65E, P59)- 212/218/112 .600/.600 camshaft, LS7 lifters, hardened pushrods, captured rocker arms, LS9 head gasket, ARP head studs, true dual exhaust with long tube headers and x-pipe.
    Microsoft Surface Pro 8, AEM 30-0310 in-line wideband.
