Results 1 to 10 of 10
Thread: I need help with this tune
    It's 2013 Silverado 4x4 5.3 with a sloppy stage 2 cam kit with pushrods valve springs DoD delete and vvt delete stock intake and exhaust. It's only running on 4 cylinders
    2,787
    real hard for the tune to cause it too only run on 4 cylinders. Did you swap the lifters?
    5BA8
    5,473
    No tune, no data log, all anyone can do is guess. You possibly didn't turn off the DoD correctly. That could cause it to run on 4.
    email=[email protected]
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,127
    It could be mechanical, electrical, fuel, ignition, or possibly tune related. Start with these first and get back with us.
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    May 2025
    thats the stock tune
    2,787
    Quote Originally Posted by bkramtruck View Post
    Does this mean you haven't changed anything in the tune, including the DOD settings?
    Attach the file directly into the forum. Most people aren't going to mess with linked files.
    sorry
    this is the stock tune
    North Carolina
    4,846
    Quote Originally Posted by BKorangeramgreentuner View Post
    This will get it back on 8 cylinders.
    2013 silverado lt tyeschulz DOD off.hpt
    thank you. my apologies the guy told me it was a sloppy mechanics stage 2 kit. it is actually a BTR GEN III & IV TRUCK CAM - STAGE 2 - V2
    BTR31218110 (212/218 .553/.553 111+0)
