Results 1 to 5 of 5
Thread: Could someone kindly check my tune for VE tuning setup
    Jun 2020
    Ohio
    5
    Could somebody check my tune to make sure I'm tuning my VE correctly using ltft/stft?
    Issue I'm having is that I've made many logs and seemingly gotten it pretty close. I log for 15-20 min then copy and paste special multiply 1/2 then smooth table some then load tune into truck then reset fuel trims and make another log and repeat. I've had the ve within 1-2% rich up to 3500 rpm or so.
    Then here is the problem I have. I want to use the wb02 sensor for the 3500 rpm and up. so i go into my tune and disable the ltft and stft. then i log and it is showing everything I've already tuned is 5-8% richer than it is with the fuel trims.
    So then i go ahead and make a few logs tuning with the wb02 and get everything back down to 0-2% error. But if i switch back to using fuel trims everything is 5% lean again.
    I just want to make sure I'm going in the right direction.
    My setup is as follows:
    2005 GMC Denali
    LQ9/4L65E
    212/22x 107 lsa truck norris cam
    1-7/8 full length headers 3" dual exhaust with x-pipe
    12574927 8100 vortec injectors
    Cold air intake
    AEM x300 wired into serial to usb
    Here is my current log and tune.
    ltftstftsep2.hpl
    ltftstftstep2.hpt
    Thank you for your time
    Advanced Tuner abc's Avatar
    Jan 2024
    953
    If I understand your quandary, your attempting to tune with the factory NBO2's, then do similar tuning with an aftermarket WBO2's? I know you mentioned a cut line of 3500 rpm but that's not the best way to look at it. Separate your tuning line with when you want the PCM to go into open loop, or more commonly referenced to PE. Tune everything below PE with the NBO2's and take care of open loop PE with the WBO2s. You can compare the two when done but don't chase your tail attempting to pit the the sensors against each other.
    Rarely will the factory NBO2's and an after market WBO2's line up perfectly. If your seeing a 3 to 5% difference between the two, your in the ball park.
    I didn't look into how you have your WBO2s controller set up, but that can be a real issue and can drastically effect the sensor output reading.
    Indiana
    374
    Quote Originally Posted by Kzhurley View Post
    2005 GMC Denali
    LQ9/4L65E
    Cold air intake
    ltftstftsep2.hpl
    ltftstftstep2.hpt
    Your closed loop is turned off if youre wanting it on for tuning with trims. closed loop enable.jpg
    Trims and widebands dont agree perfectly all the time. a 5% swing is still pretty good. Youre VE still needs some work though pretty sharp transitions everywhere on the map. Use the trims for anything other than power enrichment or wide open throttle. Once it goes into those areas you can blend where the trims end into the wideband readings. If youre going to use trims when youre all done, then rely on the trims in the areas they can cover.
    Heres a post i made a few years ago about interpolating cells on the VE table. https://forum.hptuners.com/showthrea...sepowerguru427 nowdays, I Usually only use "Paste special" the first iteration or so of changes. After that I adjust individual areas based on what the log shows. Such as if 2000rpm is lean 5% from 40kpa-70kpa then ill just richen up that specific area by 5% and retest after covering all the areas that are not where i want them to be at.
    "It'd be a lot cooler if you did."
    Jun 2020
    Ohio
    5
    Quote Originally Posted by abc View Post
    I didn't look into how you have your WBO2s controller set up, but that can be a real issue and can drastically affect the sensor output reading.
    Thanks for the reply. I?m not sure when exactly PE should be enabled at. I?ve just seen many do it around 3500-4000. On the wideband input the reading in the scanner matches what my gauge reads so i believe the math should be right. What do I look at to determine where I should have PE being enabled? I tow a lot with this truck so I don?t know how much that affects when it enables.
    Jun 2020
    Ohio
    5
    Quote Originally Posted by horsepowerguru427 View Post
    Thanks for the reply. So if I am understanding correctly, since I have closed loop disabled I?m am basically only tuning with the stft?s? Since the ltft?s are inactive currently?
    I am still trying to get the hang of table smoothing. It seems like I always smooth it too much and it ends up making that valley I see in the ve table at 2000rpm and 2800rpm on the very next log. That?s why I was wondering if I still had something enabled in the tune that I missed.
    So I should change the closed loop enable table back to stock so the Ltft will be active or should I just tune with the stft?s?
    Thanks again
