Results 1 to 5 of 5
Thread: STIT Adapt Logging
    Sep 2022
    Alabama
    11
    Question STIT Adapt Logging
    Is logging STIT (short term idle trims) versus ECT a viable way to make adjustments to fine tune Base Running Airflow?
    Thanks!
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    938
    https://forum.hptuners.com/showthrea...ow-config-help
    I believe if you go closer to the end these configurations will upload to your scanner.
    Sep 2022
    Alabama
    11
    Idle Air
    Quote Originally Posted by dhoagland View Post
    Thanks for posting!
    Question:
    Once you log your Desired Idle Air Flow vs ECT, do you then add or subtract the (STIT + LTIT) that is also logged to the Desired Idle Air Flow
    a before copying the data into your Base Running Airflow table?
    Regards
    Advanced Tuner abc's Avatar
    Jan 2024
    953
    If your LTIT is negative you subtract that number from your BRAF and if the LTIT is positive, you add that number to your BRAF table.
    You can do a cold start and make note of the STIT at specific ECT points and adjust the BRAF table based on that.
    Sep 2022
    Alabama
    11
    Thumbs up
    Quote Originally Posted by abc View Post
    Thanks for the confirmation!
    The fueling is dialed in and this pretty much the final step
    I've got the VCM Scanner all set up and ready to go...
