Just today started getting the dreaded REP message and P1514 code on my 2003 Tahoe. Recently fixed the P2135 code... replaced the TAC module, pedal position sensor, and ultimately tore into the harness where I found butt splices put in there by somebody before me (I guess when they replaced the TB connector). I cut out all the splices and soldered all the wires, and have had zero issues for over 1,000 miles of driving.
Then this morning leaving for work, I got a REP message AGAIN to my dismay... but with a P1514 code this time. Odd. Never had this issue before with all my rustling with the throttle A/B circuit correlation errors. Per a recommendation elsewhere on the forum, I 2x'd the values in the P1514 error table and was able to get on the gas enough to drive it into work just fine. If I matted it, it would REP again at between 2500-3000rpm, however this was an improvement from the first times it was happening at around 1700rpm.
Attached are the modified "2x error" tune and two logs from my way into work this morning. Maybe someone can make some sense of the data in there. I am really trying to discern if I have a MAF issue, TB/TPS issue, or whether the gremlin may lie somewhere else, maybe in the tune. I just think it's bizarre that I fixed the P2135 issues and now I have an issue with similar problem symptoms, but now with different codes.
Other relevant information... this truck has had a 6.0L swapped into it, and I had it tuned by a performance shop at that time and have made some modifications to it with the help of this forum to improve drivability etc. Effectively haven't popped the hood since fixing the P2135 issue ~1000mi ago as I mentioned.
Really appreciate any insight any of you have. Thanks in advance.
