Results 1 to 13 of 13
Thread: gen 3 5.3l cam idle and ve table tunning
    Mar 2025
    texas!
    12
    hey guys i have a 2000 silverado 5.3l sloppy stage 2 cam, springs, long tube headers, truck intake and throttle body.
    so i think im getting pretty close but thers alot to take in with all this and im loving learning it. hopefully ill have a turbo added soon with all the other goodies related to that but got to understand the easy part first ive been reading and watching videos im taking classes on hp academy. heres is my tune and a vlog or 2
    tell me what im doing wrong and right thanks for the help
    Arizona
    1,295
    do you have o2 sensors in there? i dont see them being logged
    your commanded a/f seems off to what the w/b is reporting
    its pulling alot of air at idle
    is this a street car?
    also im going to put this list here so you get an idea of what to tell us about not justss2 cam lt headers ect becuase there is lots of info you left out.
    But good first post overall , welcome.
    Vehicle make/model/year
    Tune AND data log
    Engine/size
    Axle gear ratio / tire size
    Computer and operating system used
    Type of heads (317/243)
    Transmission
    Torque convertor stall
    intake manifold
    Intake tube / air filter
    MAP part number
    MAF part number
    Injector part number
    cam used (link to specs)
    exhaust type (long tube headers, no cats, straight piped)
    pictures of engine
    pistons
    compression
    throttle body type, size and DBW/DBC
    Fuel pressure at idle and while driving
    fuel system type, FPR, pump size, returnless or no
    ect ect
    Mar 2025
    texas!
    12
    2000 silverado 5.3l
    342 rear 20 inch wheels
    P01 pcm, mvi3 pro
    862 heads
    4l60e/ stock tourq converter
    Truck intake and truck throttle body
    Factory 1 bar map sensor
    Factory 24lb injectors
    Mar 2025
    texas!
    12
    I'm in tuning in speed density. I'm commanding 14.12afr.
    Long tube headers, no cats
    Arizona
    1,295
    Quote Originally Posted by nanygoat View Post
    why? just curious, there is no right or wrong answer, i was just curious
    also when are you adding turbo?
    Mar 2025
    texas!
    12
    isn't SD better to tune the fuel map? from what I've been learning SD is easiest way to start getting things dialed in along with timing idle air and the rest witch is why im here to learn the rest hopefully
    Mar 2025
    texas!
    12
    so no one has any thoughts about the tune or data logs?
    Feb 2024
    361
    It needs tuned, your AFRs are all over the place. If its a street vehicle turn the fuel trims back on, this usually significantly helps part throttle drivability, this will also require getting both upstream O2s working, bank one sensor appears disconnected, i suspect this is where you installed the wideband? Leave the MAF failed, use the LTFT+STFT channel and plot them against the VE table in VCM scanner, then apply the corrections being made to the VE in the tune, smooth/interpolate as needed, and make sure you match the secondary VE to the primary on this OS. Fill out the main VE with the data and copy the rows/columns to the corresponding rows/columns of the secondary VE, with a failed MAF this OS defaults to the secondary table, you can also apply the SD enhanced OS that will correct this issue. Use the wideband for 4000+ RPM
    Mar 2025
    texas!
    12
    Thanks that's the reply I was looking for. So the wide band isn't good enough for tuning down low only up top?
    I did take out one of the o2 for the wideband. But why cant I juat use the wideband to do my tuning?
    Indiana
    431
    If youre going to use fuel trims to drive the vehicle around after its tuned, then use the fuel trims to correct fueling table(s) and MAF table. (as stated before, I also prefer LTFT+STFT) Use the wideband to tune anything in Power enrichment or WOT. Meaning, when you hit the pedal hard enough and your fuel status (in the scanner channels) changes from Ready/CL to Not Ready/OL then that is when you need the wideband. Dont try to pit them against each other at idle or mid throttle. Use trims until youre out of range and then blend that into a good log from the wideband that goes into areas your trims wont. Do the same for MAF.
    Once you add turbos then use the wideband for 105kpa and up to get those areas within whatever range youre looking for.
    You can just use the wideband for your tuning. If thats what youre wanting to do then just get rid of the trims and run the wideband for the whole map. I try not to do this, but on big cam and some forced induction stuff its better... You just usually get better driveability on the low end if you use the fuel trims. Although with the cam you have in a truck, you probly dont have any low end power lol
    edit- I looked at your 2nd log and it looks like youre getting a good amount of knock retard. It seems like its burst knock but i didnt see that channel being logged. I zero'd burst knock tables in your tune. See if that fixes the knock retard issue.
    Also, your VE needs some more work (according to the log) and then the idle needs attention. You can see in the screenshot that your STIT is pulling 63lb/hr.idle trims.jpg
    Youll need to get the VE in better shape before you tackle idle trims though.
    "It'd be a lot cooler if you did."
    Mar 2025
    texas!
    12
    I was just planning on tuning with the wideband using the ve tables. Its geared way to high for sure thinking of putting a different gear maybe 411. Its a big truck and I want it to be faster than it is for sure getting ready to order the turbo like in the next week or so
    Mar 2025
    texas!
    12
    So how's my timing look? I've went by the idle tune info I've gotten from here
    Arizona
    1,295
    not a time to worry about timing, too many other issues you need to deal with 1st
    I was just planning on tuning with wideband
    why? What type of driving are you doing? Is this an offraod only rig?
    what does this mean? The 05 in the shop has 5.38 gearing
    what is a big truck? What size tires? What lift? What is faster mean?
    so all of your tuning will out the window and youll need to start over.
    Without much any type of info from you it is hard to give any information to you in a way that will help. You haven’t told us anything other than a big truck with big gears and you want to go faster.
    We need more info than that to make an ‘professional type’ of recommendation.
