Results 1 to 8 of 8
Thread: VSS signal testing
    Feb 2024
    38
    VSS signal testing
    How do you all scope signals? Splice into the wire, or probe a connector? I am having a hell of a time getting my speedometer to read, which is effecting the shifting. I?ve rang all the wires out from the vss, and trans connector to the tcm. I?ve also tried multiple sensors. Speedo only shows half speed, and won?t go any higher than 25. What I see in HPtuners matches what the Speedo shows. I?m very desperate, any help would be greatly appreciated.
    Tuner DanN's Avatar
    Jul 2019
    Shuswap, BC, Canada
    52
    What is your vehicle config?
    If you're getting any speed signal at all, it's likely the wiring is OK. You could have an issue with the sensor or with the speedo config. You should upload your tune and a log.
    If you want to scope the speed signal you'll need some sort of scope. At a minimum, you may be able to use a normal AC multimeter to measure AC voltage between the VSS wires. I have used a cheap Aliexpress oscilloscope for looking at various signals, including VSS.
    1972 Triumph Spitfire Ecotec Swap:
    Stage 1: MEFI-4B & L61 - deceased; ate it's own balance shafts - because I did a dumb.
    Stage 2: E37 & GenII L61 - Ran great, but too meh.
    Stage 3: An LSJ is a good time in a 2000# car.
    2005 GMC Canyon base work truck.
    LS Swap, AR5 Trans, BCM transplant, Sierra Dash, G80
    Feb 2024
    38
    The vehicle and hardware is
    07 trailblazer ss awd
    4l80e converted with bw-4485 t case from Escalade.
    E67 ecm
    T42 tcm
    4l60 to 80 adapter harness from pcmofnc
    Ecm and tcm both from pmcofnc set up for my truck and trans.
    I have a scope, I’ve never used it before but it was too good of a buy to pass up. I might have a log, I’ll report back when I can.
    Thwnks for the reply.
    Feb 2024
    38
    h2.hplh1.hplh.hpl
    Some logs I uploaded the other day.
    Tuner DanN's Avatar
    Jul 2019
    Shuswap, BC, Canada
    52
    Quote Originally Posted by Tonyorlo View Post
    h2.hplh1.hplh.hpl
    Is the temperature data accurate? Like, you're running at 235F+?
    Feb 2024
    38
    It was at that moment. The e fans weren’t kicking on, helps to have the ground landed. That was the first drive after swapping the trans.
    Feb 2024
    38
    pcmofnc tune.hpt
    the tune
    North Carolina
    4,857
    This isn't our tune. this is just what is needed to get the 4l80 going.
    Is the wiring all stock? The wiring for VSS are normally a twisted pair to cancel noise.
