I have an 09 Colorado stock 5.3. Volant intake and exhaust. Replaced the MAF but still get a ton of bog and delayed throttle under 3k. In straight VE without the MAF plugged up it drives great. I'm assuming there is a design issue with the Volant as I'm not getting any Codes other than rear O2 due to the HF Cats. LTFT are in the -11 to -14 range mostly. I've included a revised tune that I have not loaded yet. I'm new to this so please let me know if I'm doing something wrong.
Pulled the MAF Down below 11k HZ and added above it to bring it back to near stock in attempt to fix the ltft and bog. Also need to turn the MIL off the the Rear O2s.
Colorado 5.3.hplJosh Carpenter 2009 Avalanche A6 6.2L 216-228-112 50lb inj BIG MAF LTH 4.10 PG tune 6.hpt
